Oil Pan Spacer
Old Oct 30, 2005 | 07:54 PM
350zDCalb's Avatar
350zDCalb
builtZmotors
hey dave...
my driver side turbo oil feed line has leaked since i had the lines re-made...(i was trying to prevent any leakage problems last time i had my motor out-instead, it has been a problemever since)...
i had an issue with the fittings that the shop used with the greddy turbo banjo fitting, the fittings they used didnt allow the banjo to sit flush and tight against the turbo, instead it left a small little gap...i have taken the line off 2 times and tried to correct the fitting so that it met the turbo flush and sealed perfectly....still leaks...are you guys selling line that feed the turbos??? if so, what is the price?...i am sick of this oil leak...and sick of having to pull this feed line off (PITA to do so with the turbo on, fortunately the driver side one allows you access to the bolt on top of the turbo to remove the line-getting it back on with the two copper washers is the tough part!!!)
Old Oct 31, 2005 | 06:24 AM
dynamic6er's Avatar
dynamic6er
Originally Posted by MIAPLAYA
Did I miss it? When will these be available...
The spacers are available now. We have them in stock and ready to go. We are still in the development stages of the line kits. I can send out the parts for the line kit if you feel confortable assembling Braided Steel AN line. (ie-NPT to AN adaptors, 45 and 90 deg hose ends, line, and male to male adaptor for the spacer itself)
Old Oct 31, 2005 | 06:33 AM
dynamic6er's Avatar
dynamic6er
Originally Posted by 350zDCalb
hey dave...
Unfortunetly Greddy uses some very specific Metric lines with reverse flares that aer not common or easy to find in the U.S. What we would need to do is convert the metric thread at the turbo and the oil pressure sensor adaptor to -03AN size and then run AN line between the two. Let me measure the threads of the banjo bolt and look at some of the space we have to work with. I can get something made up for you. The one thing though is that there may not be any real benefit. It may be faster and less expensive to get new Greddy parts. The turbos may need to come down to accomplish either option.
Old Oct 31, 2005 | 06:56 AM
350zDCalb's Avatar
350zDCalb
builtZmotors
well, keep me posted... i figured if u guys were making the lines i'd get a new set, so you think i should go through greddy? i was trying to get a higher quality line...
thanks
Old Oct 31, 2005 | 07:59 AM
dynamic6er's Avatar
dynamic6er
thanks
The line kits we are making are the return lines. I think you're looking for the feed lines?
Old Oct 31, 2005 | 03:52 PM
redline350ZZ's Avatar
redline350ZZ
Technically the Turbonetics kit is the same way however I know several people personally who are running the return to the pan spacer (JWT that is) And JWT runs their own returns there.
Do you know what their expirence was tapping a JWT...I just bought 1 before I knew about this product......
Old Oct 31, 2005 | 03:54 PM
MIAPLAYA's Avatar
MIAPLAYA
They had good experience doing that...drilling right into the side of it...
Old Oct 31, 2005 | 06:30 PM
350zDCalb's Avatar
350zDCalb
builtZmotors
correct, i need the feeds
Old Dec 5, 2005 | 09:22 PM
Tekwon-V's Avatar
Tekwon-V
Is the groupbuy still on?
Old Dec 6, 2005 | 08:09 AM
Alberto's Avatar
Alberto
Cranky FI Owner
+1
Old Dec 6, 2005 | 08:57 AM
trinig35's Avatar
trinig35
Old Dec 6, 2005 | 04:54 PM
jdm3fiddyZ's Avatar
jdm3fiddyZ
im in for the GB
Old Dec 6, 2005 | 07:41 PM
dynamic6er's Avatar
dynamic6er
Ok guys Ill have the post ready to go tomorrow morning Line kits will be ready too!
Old Dec 6, 2005 | 08:31 PM
Tekwon-V's Avatar
Tekwon-V
yay! :-D i've been checking this thread nonstop.
Old Dec 6, 2005 | 08:32 PM
meatbag's Avatar
meatbag
Im in for the GB
Old Dec 6, 2005 | 08:41 PM
Tekwon-V's Avatar
Tekwon-V
can i just use the spacer kit (w/o the line kit) and use the line provided by the Turbonetics kit?
Old Dec 7, 2005 | 06:49 AM
dynamic6er's Avatar
dynamic6er
You can. Not a problem One thing to note is that the threads on our spacer are not the same as the threads on the Tubonetics fitting. This is not an issue if you already have your factory pan tapped, but if you want to install the Tnetics fittings into our pan you will have to retap for the NPT fitting Turbonetics provides.
Old Dec 8, 2005 | 08:35 AM
  #38
jdm3fiddyZ's Avatar
jdm3fiddyZ
any new info on this?
Old Dec 8, 2005 | 08:49 AM
  #39
Alberto's Avatar
Alberto
Cranky FI Owner
GB has been posted in general performance section.....
Old Dec 8, 2005 | 02:36 PM
  #40
dynamic6er's Avatar
dynamic6er
Here you go..
https://my350z.com/forum/showthread....84#post1912984
