Engine code P0011 ???
Old Nov 3, 2005 | 06:56 PM
Dirty Dave's Avatar
Dirty Dave
Default Engine code P0011 ???
I looked up this code which my car keeps tripping, intake valve timing control. What does this reall mean, and is this common to all the guys with built tt motors ?
Old Nov 5, 2005 | 11:01 AM
Dirty Dave's Avatar
Dirty Dave
Bump can anyone help me out or have no one ran into this problem ? I have test pipes if that matters.
Old Feb 15, 2006 | 02:57 PM
failsafe306's Avatar
failsafe306
Just found out that mine is throwing the same code. Could it be because of my JWT cams, and is it anything to be concerned about?
Old Feb 15, 2006 | 03:12 PM
drsifu's Avatar
drsifu
not sure, but it may a cylinder misfire code.
common with forced induction set-ups. not sure why it is common, but simply disconnnecting the negative battery terminal should get rid of it.
Old Feb 15, 2006 | 09:11 PM
overZealous1's Avatar
overZealous1
possible causes for the po011 code is crank pos sensor, cam pos. sensor, or accumulation of debris on the signal pick up portion of the cam. po011 is for bank 1 or the passenger side.
i would pull the sensor and see if you have any debris on it. i light slurry of metal can accumulate on the sensors after cam and bearing break in. had it happen on mine, but mine didn't through up a code. if not, start either replacing sensors or go to nissan and they would be able to see the sensor giving the wrong output signal with the consult 2. good luck.
Old Feb 16, 2006 | 01:35 PM
failsafe306
Thanks Scott
liqalu04
Jan 2, 2022 12:58 PM
Fixxxercask
Nov 9, 2015 11:10 AM
Detailed Image
Cleaning & Detailing
Sep 28, 2015 03:03 AM
