any utec installs yet?
Old Nov 4, 2005 | 01:33 PM
overZealous1's Avatar
overZealous1
Default any utec installs yet?
was curious if anyone has had a chance to install or tune with the utec yet. i have now had my car together for 3 months and have gone through an e-blue, an eu, and my stock ecu, plus 4 coils. my car has yet to run correctly except for the first hour when it was completed. i was always joking about getting it done in time for the snow, but looks like that may even be to early of a prediction!
i noticed the timing control on the utec uses real timing inputs in degrees and is plug and play. it would eliminate the need for reflashes associated to the stock ecu timing map changing. is this true or am i understanding it wrong. i am also interested on the knock control functions of the unit.
Old Nov 4, 2005 | 03:37 PM
overZealous1
m
Old Nov 4, 2005 | 03:42 PM
sentry65's Avatar
sentry65
the burninator
no
Old Nov 4, 2005 | 03:45 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
The UTEC wont be shipping for a couple more weeks, so the only people that are using them are the beta tester shops. It's going to be a great unit, no question.
Old Nov 4, 2005 | 04:08 PM
overZealous1
bummer, i thought it was released a few days ago. if i decide to go this route i will be contacting you sharif. wait a minute, i already left a message for ya, hahhaa. give a holler when you get a chance.
Old Nov 8, 2005 | 07:38 AM
TurboXS_Nathan's Avatar
TurboXS_Nathan
I suppose it's time to come out of lurk mode. I work with Jermaine at TurboXS. I am the shop manager, and with the release of the zUtec just around the corner this topic looks like a good spot to give a quick update on the tasks that need to be completed prior to shipping.
The first batch of the zUTECs is on their way to us now. I expected them while we were at SEMA, but they were delayed because the bench test procedure could not be automated prior to the departure of key TurboXS staff for the SEMA show. This caused a slight delay as testing each and every connection by hand is rather time consuming. I expect the first small batch of the zUTEC to arrive sometime later this week.
Before they can be sent out two important tasks must be completed. First, we must finish the documentation. Jermaine and I will be collaborating on this. He will write the actual install instructions, and I’ll do the rest of the documentation. We’d like to have this finished and to the printers by late Wednesday afternoon, but with yesterday being almost a throwaway day trying to catch back up from SEMA it might not happen until Thursday.
Secondly, we need to get a few more stock cars on the dyno to do some data logging for base-map building. The zUTEC is quite a bit more advanced then any ECU product we’ve ever released, so much so that we almost don’t even want to call it a UTEC, and as such it requires much more work on our part to make sure that the base maps are actually usable. Our intention at this point is to provide a limited number of MAF pull down based maps as well as a few speed-density, injector pulse width maps. This map library will grow, but at the start will be somewhat limited. With this in mind, it is likely that actual tuning shops will get first dibs on the zUTEC for use in cars they intend to actually dyno tune as their efforts will help us grow our library. We will also give some preference to cars that we can get here on our dyno to ensure that everything goes as smoothly as possible with this product release.
Lastly, each zUTEC will need to start and drive Jermaine’s car as a pass/fail test.
Based on the above, it is likely that we will be shipping units out a few at a time starting Monday. By the middle of next month we should be up to full capacity
For the most part Jermaine is going to be handling the Z market, so you’ll likely hear much more from him then you do from the rest of the TurboXS crew. However, we are all very excited about this new ECU as its capabilities and performance set a new bar for our electronics products. It’s also nice to have another group of car owners around the shop.
To answer your technical questions, the zUTEC has absolute timing control with a built in knock retard scheme (which is user definable) to allow you to determine how the unit reacts to feedback from the knock sensor. It also gives you the ability to increase your rev-limit. These features will save you a few bucks since you do not need to purchase a re-flash to use with the zUTEC. In addition since it plugs in, it will save you from purchasing a wiring harness. If you intend to run the car in speed density, the only thing you’ll need to purchase is a TurboXS map sensor.
…back to work
Old Nov 8, 2005 | 01:02 PM
overZealous1
thanks for the info, look forward to updates.
Old Nov 8, 2005 | 05:22 PM
theking's Avatar
theking
Kudos! You guys are true FI guys and it's great to see a company with their hand on the pulse of the market. Can't wait!
Old Nov 10, 2005 | 06:16 PM
35ounces's Avatar
35ounces
03 CS Track 6MT
sounds fishy
Old Nov 10, 2005 | 06:36 PM
diegonismo's Avatar
diegonismo
Originally Posted by 35ounces
sounds fishy
its real
Old Nov 10, 2005 | 06:37 PM
Gman2004's Avatar
Gman2004
sounds fishy
This is like the 3rd thread this guy posted in about selling the UTEC. He is about a half a heart beat from being banned.
Old Nov 10, 2005 | 06:44 PM
marks350Z's Avatar
marks350Z
does anyone know how the beta testing went? My motor is being built right now and I want a great tune with minimal problems! the zUTEC sounds very promising, but I guess there is always a risk when you are one of the first to try it out.
Old Nov 10, 2005 | 06:47 PM
overZealous1
Originally Posted by diegonismo
I have 10 utec for 350Z for only $869.00 plus shipping. If you have any questions, please feel free to contact me at:raue@hotmail.com
just curious, but how did you end up with 10 of them when there is only going to be 25 on the first release? plus selling them for nearly $200 below msrp? you better do your homework better if you are pulling a scam, utec has not even released it yet!!!
Old Nov 10, 2005 | 06:51 PM
diegonismo's Avatar
diegonismo
the release is next week and the price are because i not have a shop i buy from a friend in orlando and give me beter price because i buy many items for my cars and the store are www.titanmotorsports.com in orlando florida.
Old Nov 10, 2005 | 07:18 PM
2slo2bfurious's Avatar
2slo2bfurious
...if that's the case, I drive by Titan almost daily, can I pick one up there for that price instead of getting it shipped?
Old Nov 10, 2005 | 07:29 PM
diegonismo's Avatar
diegonismo
titan are not going to give you this price for you. they gime this price because i have papers of one nissan dealers in Puerto Rico. and my car appears in the custumers cars whith the old configuration
Old Nov 10, 2005 | 08:38 PM
2slo2bfurious
...so I have to have them ship it from where I live to you, then you ship it back here with international shipping charges from PR? Sound's real fishy man....
Old Nov 10, 2005 | 08:40 PM
diegonismo's Avatar
diegonismo
ok if you no trust i not have any problem i garantee you never find this price but is ok to me good luck
Old Nov 11, 2005 | 04:49 AM
bobby1652's Avatar
bobby1652
Thumbs up
I have purchased lots of stuff true DiegoNismo and he has always delivered great products at excellent prices. I have got all my up grades with him and I have definitively saved lots of money.
Old Nov 11, 2005 | 05:30 AM
35ounces's Avatar
35ounces
03 CS Track 6MT
with one post that very convincing....NOT
