Turbonetics ST not fit 06 300hp engine
Old Nov 10, 2005 | 12:32 PM
RED HOT Z's Avatar
RED HOT Z
Default Turbonetics ST not fit 06 300hp engine
Is this correct because I just ordered a 06 GT and was planning on tossing on the turbo as soon as I receive my new car and if this isn't going to be possible I don't know what I will do. CRAP!
Old Nov 10, 2005 | 12:34 PM
MIAPLAYA's Avatar
MIAPLAYA
From what Turbonetics told me it should fit but the flash is not done for the kit. It will be done by then end of feb from what I have been told. If you already ordered you can put it on hold or get the kit and wait till the flash is done.
Old Nov 10, 2005 | 12:39 PM
RED HOT Z's Avatar
RED HOT Z
Thanks for all your help^^
MIAPLAYA's Avatar
MIAPLAYA
No worries...
Old Nov 10, 2005 | 12:40 PM
RED HOT Z's Avatar
RED HOT Z
any other way to get around it
Old Nov 10, 2005 | 12:44 PM
JonathanG35's Avatar
JonathanG35
you should be able to drive to TS and throw it on the dyno and have them tune/flash it for you.
Old Nov 10, 2005 | 12:45 PM
RED HOT Z's Avatar
RED HOT Z
Really will it be as reliable
Old Nov 10, 2005 | 12:48 PM
MIAPLAYA's Avatar
MIAPLAYA
TS has not cracked the 06 ECU yet so until then you could get the tuner kit and use another form of management. But as far as using a flash no way around it now.
Old Nov 10, 2005 | 12:54 PM
RED HOT Z's Avatar
RED HOT Z
might as well wait till feb
Old Nov 10, 2005 | 12:56 PM
BoOsTedz33TT's Avatar
BoOsTedz33TT
you can always spring for a HKS Fcon Vpro, trust me, youll be very happy, costly though
Old Nov 10, 2005 | 01:04 PM
RED HOT Z's Avatar
RED HOT Z
hmmm Ill have to luck into that
Old Nov 10, 2005 | 01:07 PM
g356gear's Avatar
g356gear
Install a UTEC
Old Nov 10, 2005 | 01:08 PM
RED HOT Z's Avatar
RED HOT Z
Will I have to have it tuned or the Hks fcon will take care of that
Old Nov 10, 2005 | 01:13 PM
RED HOT Z's Avatar
RED HOT Z
A UTEC where do I get that
Old Nov 10, 2005 | 03:15 PM
hndumafia's Avatar
hndumafia
i think forgedinternals is having a gb on the utec. contact sharif for info.
Old Nov 10, 2005 | 03:31 PM
MIAPLAYA's Avatar
MIAPLAYA
They sure do... www.forgedinternals.com
Old Nov 11, 2005 | 07:58 AM
CpraceZ's Avatar
CpraceZ
I heard diffrent, word has it that the boost tube is going to hit the front cover, atleast that is the case on the 6MT 05 G35s which has the same motor so I would think the same.
Old Nov 11, 2005 | 10:39 AM
RED HOT Z's Avatar
RED HOT Z
OK ^^ so which is it does it physically fit or not
Old Nov 11, 2005 | 10:47 AM
CpraceZ's Avatar
CpraceZ
from my understanding Turbonetics has not done a car with the 300hp motor so it sounds like they are just assuming it will not fit, they have said they do have customers with the 300hp motor running the turbonetics kit, but they have had to do a custom boost tube.
Old Nov 11, 2005 | 10:57 AM
RED HOT Z's Avatar
RED HOT Z
ahh I see then **** it so will I
