Turbonetics TAP missing??
Old Nov 10, 2005 | 10:39 PM
redline350ZZ's Avatar
redline350ZZ
Default Turbonetics TAP missing??
Turbonetics TAP the 1/8 NTP one...Tap required near the oil filter wasn't in my kit....( it is supposed to be in another blue case right?????I know I should have done a better check before I started...anyway im just wondering if something I but from a store like sears will equate to the kit part....I just dont wanna have to wait till Monday/ Tuesday to finish...thanx
Old Nov 11, 2005 | 05:48 AM
35ounces's Avatar
35ounces
03 CS Track 6MT
mine was missing too just call Reggie and they will send you one.
Old Nov 11, 2005 | 06:57 AM
JETPILOT's Avatar
JETPILOT
well.... Turbonetics sent my reflashed ECU to my house in FL while me, my car and my installer are 500 miles away here in NC.
Respect
JET
Old Nov 11, 2005 | 07:15 AM
Midnyte's Avatar
Midnyte
Only one of my taps was in a blue plastic case. The other was rolled up in a small turbonetics ziploc bag in the box with all of the hardware (screws, washers, etc). I thought I was missing it until I dug through all of the hardware and found it.
-Blaise
Old Nov 11, 2005 | 05:15 PM
Peking's Avatar
Peking
Respect
JET
JET did your shop not write out a correct return address?
Old Nov 12, 2005 | 10:37 AM
redline350ZZ
Im just gonna go out and buy 1 Reggie said it was the same as any store bought tap of that size.....
On another note ....for the BOV and the Wastegate Hardware is only supplied for 2 of the 4 fittings(2 on each 4 total) does that mean that 1 from the wastegate as well the BOV is open to the atmosphere??????
Old Nov 12, 2005 | 11:48 AM
MIAPLAYA's Avatar
MIAPLAYA
Yes however its not what you are thinking. These other ports are in a completely different chamber of the device so having them open does not affect operation. Any wastegaste or BOV you find on any other kit is the same way. (if its an external a la Greddy). You connect the boost signal line from the plenum to the TOP port on the BOV and the compressor boost signal line from the compressor outlet to the BOTTOM port on the wastegate. In both cases the other port is going to another sealed off chamber and is not used unless you are adding a boost controller or using an alternate config of the BOV.
Old Nov 12, 2005 | 01:24 PM
redline350ZZ
Anyone have the Exact Spec's of the 1/8 Turbonetics TAP......
Old Nov 12, 2005 | 08:21 PM
redline350ZZ
Anyone know????
Old Nov 13, 2005 | 08:51 AM
MIAPLAYA's Avatar
MIAPLAYA
Originally Posted by redline350ZZ
Anyone know????
I think its just a standard 1/8 NPT tap...Are you sure it didn't get tossed around somewhere...
Old Nov 13, 2005 | 11:54 AM
redline350ZZ
Well the First tap is a 3/8-18 NTP....There are fine tread....course thread taps.....thats why I need the exact number.....If I use the wrong Tap.....Im screwed.....Ill call Turbonetics on Monday if I cant find the info......I didnt know Taps were so specific till yesterday..... hehe
Old Nov 13, 2005 | 12:01 PM
spazpilot's Avatar
spazpilot
redline350ZZ :
Wow!!!! I was just looking at your sig. and with the gears and the flywheel(thats the really light one if I am not mistaken 8lbs approx), your first gear will be useless on street tires with a turbo kik.
Old Nov 13, 2005 | 12:04 PM
redline350ZZ
I will be running BFG Drag Radials 275-35-18 ASAP...after I burn out my Kuhmo MX's I live 2 miles from work so I dont anticipate too much Heavy Foot...
But anyways Bout the TAP
Old Nov 13, 2005 | 01:22 PM
MIAPLAYA's Avatar
MIAPLAYA
I dont have the tap myself or I would tell you sorry...maybe pm kcobean, peking, solidsnake, taurran, or 12NV.
Old Nov 13, 2005 | 02:05 PM
Peking's Avatar
Peking
Shop who did the install kept the tap
But I got mine from Reggie.
Old Nov 13, 2005 | 02:08 PM
35ounces's Avatar
35ounces
03 CS Track 6MT
LOL, my shop kept it too.
If you had asked Reggie to send it to you when you started this thread you would have it by now.
Old Nov 13, 2005 | 02:45 PM
meme's Avatar
meme
i'm half way done with my install. i will look at the tap tonight. what i did was use an adaptor. the male end is bspt and the rest of the ports are npt(3 ports) . that way you don't need to retap the hole. i used this so i can mount my greddy oil pressure sensor. i used the tap that came with the kit for the fuel pressure. drilled and tap at the tip of the rail.
Old Nov 13, 2005 | 02:52 PM
MIAPLAYA's Avatar
MIAPLAYA
Hey Jet i saw your other thread but just saw the post about the ECU...ditto for the address did you put your house on there on accident?
Old Nov 13, 2005 | 03:02 PM
redline350ZZ
where did you get the adapter from???? anything that allows me to not Tap is kew lby me....
Old Nov 13, 2005 | 03:03 PM
G352NV's Avatar
G352NV
Nice of them to include it with the kit. When I did my old Vortech I had to run all over town looking for a tap. Man that sucked! It would have been nice if Vortech would have included it.
