TurboSystem is in
Old Nov 11, 2005 | 03:58 PM
meatbag's Avatar
meatbag
Default TurboSystem is in
Its so close
Old Nov 11, 2005 | 04:04 PM
DBZ33's Avatar
DBZ33
Who makes that system? Is it custom?
Old Nov 11, 2005 | 04:06 PM
meatbag's Avatar
meatbag
Oops knew i forgot something, Its the SFR/SSR turbo system with T60-1 hifi turbos
Old Nov 11, 2005 | 04:09 PM
failsafe306's Avatar
failsafe306
How big are those downpipes? That's NICE!! What's the price on that lovely piece of work?
Old Nov 11, 2005 | 04:10 PM
myehrick09's Avatar
myehrick09
How much did this Turbo kit set you back? Does it come w/ emanage system? I don't see one on the pic.
Old Nov 11, 2005 | 04:14 PM
jcpeyton's Avatar
jcpeyton
Oh my, that's beautiful. Please report back. Lots of us are interested. Thanks.
Old Nov 11, 2005 | 04:20 PM
g356gear's Avatar
g356gear
http://g35driver.com/forums/showthread.php?t=74483
Old Nov 11, 2005 | 04:42 PM
tig488's Avatar
tig488
looks good, but i got one important question, what is that cannister between the manifolds, right next to the turbo that has 3 ports, please tell me thats an oil reservoir! and isnt that a sump pump for oil return?
Old Nov 11, 2005 | 05:10 PM
g356gear's Avatar
g356gear
Yes they run a sump system....same as APS ST.
Old Nov 11, 2005 | 05:27 PM
tig488's Avatar
tig488
on the picture on G35driver, you can see that cannister in between the two turbos and it looks like the oil returns go to it.
Old Nov 11, 2005 | 05:47 PM
tinman's Avatar
tinman
T60-1 Hi-Fi
Old Nov 11, 2005 | 05:52 PM
Sly_Z's Avatar
Sly_Z
makes u drool huh?
Old Nov 11, 2005 | 07:00 PM
meatbag's Avatar
meatbag
Yeah the canister is an oil sump tank for the turbos and the pump is to pump the oil back to the oil pan since the turbos sit low and farther back out of the engine bay. The downpipes are 2.5". THe outlet on the turbos is 2.5" so it should be plenty. I didnt order it with an emanage or anything b/c i already have the HKS F-con Vpro waiting. I would have to find the price again, i added extra things like polished piping and got ball bearing turbos
Old Nov 11, 2005 | 09:35 PM
D350Z10's Avatar
D350Z10
VEry nice i noticed that turbonetics makes those turbos... SWEET, thats is one kick *** kit!
Old Nov 12, 2005 | 02:14 PM
undRgrNd350z's Avatar
undRgrNd350z
then which is better? aps TT or this kit???
Old Nov 12, 2005 | 02:24 PM
G352NV's Avatar
G352NV
Is that all the parts?? If so thats a TON less then APS TT.
Old Nov 12, 2005 | 03:04 PM
undRgrNd350z
i just got off the phone w/ the owner/installer here in San Diego, CA. the kit sounds really good and is a custom job. he said he can interchange parts for the individual customer (i.e. turbos, wastegate routing, more stuff i didnt understand) this way, you can either be a track abuser, like me, or a dyno queen, for those of you who are. he is more knowledgeable and customer friendly than any other turbo shop i have ever called. the kits are custom ordered, (4 weeks) and the install takes 5 days. he is running a low psi w/ high numbers. he will let you drive his car to make the choice of either having the blow off valves re-routed or put into the atmosphere.... looks like i will be going for his kit this spring. =)
Old Nov 12, 2005 | 03:08 PM
meatbag's Avatar
meatbag
My kit has alot less parts then what normaly comes with the SFR/SSR kit because i am using my own fuel system, engine managment, etc..
Old Nov 12, 2005 | 03:15 PM
zland's Avatar
zland
Sport Z Magazine
If you want to know more about the maker of this kit, check out the the 2005 summer issue of Sport Z Magazine. Speed Force Racing (SFR) let us test his kit on a beautiful red G35 coupe. Tim does a great job and is willing to customize the kit to fit your needs. As I stated in the article regarding the SFR kit "Custom turbo kit philosophy comes to the masses". His stainless steel tubular exhaust manifolds are a work of art.
Old Nov 12, 2005 | 06:14 PM
Wholey Smokes's Avatar
Wholey Smokes
Wow. I built a custom turbo kit for my last car and I must say that SFR's work is amazing. Those manifolds are beautiful and all the IC piping is bead-rolled.
You are going to put out some great numbers with the FCON. Great choice on kit and engine management.
skyydiver
Sep 14, 2006 05:02 PM
