What 1/4 times are you getting?
Old Nov 14, 2005 | 09:55 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Originally Posted by BriGuyMax
The more worn down they get...the better they hook. I'm assuming you're running the 295/35-18s...right? Did you heat them up and lower the pressure?
C5 or C6?
C5 Z06, and I was running the 295's...correct.
Ran 15-17psi of pressure...we played around with it a bit to come to that number....seems to hook up nicely, with no wheel hop. Did a really long burnout....holding the car in place with the foot brake. We disabled the ABS so I could get a pretty decent burnout.
Old Nov 14, 2005 | 10:13 AM
ZMIKEMAN's Avatar
ZMIKEMAN
So, thinking of going to the Rock on the 27th? If you do, keep an eye out. I'm pretty sure my dad and I will be out there. Last import event at the rock this season. Hope they prep good.... none of that fwd only prep junk they usually do.
Old Nov 14, 2005 | 10:26 AM
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
Cool...sounds like you did everything you needed to do to hook well. Were you getting some spin in first?
Old Nov 14, 2005 | 10:38 AM
002-M-P's Avatar
002-M-P
Wanna come to the next event and give it a whirl?? Nov27th.....I'll hand you the keys.
I was gonna ask if you were gonna go to that one, as I am was seriously thinking about it. Drag racing gets addicting very fast I am thinking.
Old Nov 14, 2005 | 05:42 PM
NJzguy03's Avatar
NJzguy03
Thanks for the help guys on the street slicks. I hope to come accross a good deal on some over the winter lets see what happens
Old Nov 14, 2005 | 07:06 PM
jy535's Avatar
jy535
njzguy..... how muich h/p to the wheels..... im running a similar setup...... procharger 7lbs. intake plenum spacer AAM, AAM computer, borla tru dual, pr0-1 straight pipes....... 363whp 300tq
Old Nov 14, 2005 | 07:18 PM
Sharif@Forged
Forged Performance
Yeah, its a fine line between too much spin, and not enough. I did hit a 1.888 60ft, but then shifted from 3rd to 6th....oops.
Old Nov 14, 2005 | 08:46 PM
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
Wow...that's talent...I can't even hit a fast 5-6 shift if I want to...
Old Nov 14, 2005 | 09:33 PM
DBZ33's Avatar
DBZ33
For the record, I am the first to admit that I am a crappy drag racer.
60ft times 1.97
ET: 11.6
Speed: 125mph
I bet if I put BriGuy behind the wheel, he would have punch it into the 10's.
Shouldn't your MPH be higher with over 600 RWHP? I'm not tring to say anything bad but I just would like to know.
Old Nov 15, 2005 | 04:44 AM
1up's Avatar
1up
He's probably not hooking up very well in 1st or 2nd.
Like he said, with a better driver, or some better launches he should easily break into the 10s with traps 130+.
Old Nov 15, 2005 | 05:42 AM
Sharif@Forged
Forged Performance
I dont know...you guys tell me. My guess is the car was putting downa around 600whp, as I never dynoed again after fitting the 3 inch HKS mufflers. But you also have to understand, that the law of diminishing returns kicks in. The different between 400 and 500whp is much great than the difference between 500 and 600whp. My guess is with a better launch out of the hole, I could trap 127-130mph. Cars running 125mph traps are typically in the high 10's.
Old Nov 15, 2005 | 06:13 AM
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
Do you have a dyno sheet handy...I want to plug it into cartest and see what it spits out. When I plugged my cars numbers in it spit out 11.6@121mph which is VERY close to what I actually run.
Old Nov 15, 2005 | 09:37 PM
NJzguy03's Avatar
NJzguy03
i am at about 380whp to 390whp
Old Nov 16, 2005 | 07:39 AM
Sharif@Forged
Forged Performance
Do you just need the peak numbers? 622/604 IIRC on the trq number
Hey, I dont feel as bad anymore about my numbers.
I was looking at the Dec04 issue of Modified Mag, and they had an article about the Performance Motorsports (street) drag car. This is a street chassis, but designed for drag racing. Weighs about 2800lbs, and is fully speced for dragging. At the time, that car was making 596/599trq, and ran an 11.1@126mph. So I am very close to this setup. If I can get my launch down, I have no doubt the car will run 10's. The performance motorsports car was running drag radials as well.
Old Nov 16, 2005 | 07:43 AM
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
It's more accurate to have the whole curve, but we'll see what I can come up with on the peak numbers interpolating off my curve...
Old Nov 16, 2005 | 07:49 AM
Sharif@Forged
Forged Performance
Here you go:
Old Nov 16, 2005 | 07:57 AM
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
cool...I should have results for you in a couple hours...have some other things to take care of first...
Old Nov 16, 2005 | 11:58 AM
  #38
Sharif@Forged
Forged Performance
Anything yet.
Old Nov 16, 2005 | 05:17 PM
  #39
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
Anything yet.
Cartest spit out 11.19@129.86 if you pulled a 1.70 60'
And cartest is usually within about 1 tenth and 1 mph of what you actually can run. Get some slicks for that badboy....
Old Nov 16, 2005 | 06:26 PM
  #40
Sharif@Forged
Forged Performance
Nice...looks like I need more practice. I know a 1.7 is doable on drag radials..without enough practice.
