Idle problem after motor build
Old Nov 14, 2005 | 06:00 PM
KPierson's Avatar
KPierson
Well, I had a TT installed (Unichip), dropped my compression to 8.6:1, and installed aggressive cams.
My motor was much different then stock. So, this may fix your problem, it may not. Whats your compression now?
Old Nov 14, 2005 | 06:11 PM
Z BOY's Avatar
Z BOY
Originally Posted by jdm3fiddyZ
So does mostly everyone that has the JWT flywheel have this same idling problem?
i have it and have not had any idle problems, nor have i heard of this problem with this mod, alone.
Old Nov 14, 2005 | 06:14 PM
jdm3fiddyZ's Avatar
jdm3fiddyZ
We kept the stock compression at 10.3 because of the centrifical charger...woulda dropped it if i had a turbo setup...so apparently it is the idle learn problem that the ecu is having...guess we'll find out
Old Nov 14, 2005 | 06:46 PM
G352NV's Avatar
G352NV
Any check lights? If so check plug wire locations.
Old Nov 14, 2005 | 06:48 PM
jdm3fiddyZ's Avatar
jdm3fiddyZ
nope, no check lights
Old Nov 15, 2005 | 02:44 AM
Machupo's Avatar
Machupo
if you artificially hold the idle at ~900-1000 does it still stumble/stall? if not, just reset your idle
edit:
(i had my idle reset to 1000 after my engine build, but then i had a bit of head work and pretty aggressive cams put on along with lowering the compression / lw flywheel, etc...)
Old Nov 15, 2005 | 06:36 AM
jdm3fiddyZ's Avatar
jdm3fiddyZ
edit:
Yeah i can hold it there and it would be fine, but as soon as i let go, it stalls after a few seconds...to reset the idle, are you talkin bout the throttle learn process?
Old Nov 15, 2005 | 10:24 AM
BrianLG35C's Avatar
BrianLG35C
How ironic, I just started having the same idle problem while in rush hour traffic! My engine isn't built but I'm running TTs. I've been told by GRD it's probably an IC hose disconnection but I couldn't see anything so I'm having it checked by a local tuner.
Old Nov 15, 2005 | 11:16 AM
tinman's Avatar
tinman
it is a very common problem with built motor.
relax,just bring it to any nissan or infiniti dealer and have them raise the idle.should cost less than $100.
Old Nov 15, 2005 | 12:39 PM
jdm3fiddyZ's Avatar
jdm3fiddyZ
Ok we have a new problem, Nissan just called me back and said that there is NO oil pressure at idle and thats why it wont idle. They dont know what would cause that, so now im out of ideas...Should i tell them to just raise the idle? would that fix the problem?
Old Nov 15, 2005 | 01:20 PM
t32gzz's Avatar
t32gzz
I had my idle raised via Technosquare reflash to 1000 rpms due to cams and head work. If you have low oil pressure at low rpms, that is normal. What is the oli pressure if they hold it at 1K rpms?
Old Nov 15, 2005 | 01:29 PM
jdm3fiddyZ's Avatar
jdm3fiddyZ
i dont know exactly what rpm it is at when they hold it at 1000, they just said that there is pressure when they are on the throttle. Is it possible for the dealer to raise the idle rpm?
Old Nov 15, 2005 | 05:00 PM
Z BOY's Avatar
Z BOY
on an 03, yes.
Uriyo_
Sep 8, 2021 08:46 AM
