EU question. Speed sensor pin?
Old Nov 20, 2005 | 06:25 PM
fito's Avatar
fito
Post EU question. Speed sensor pin?
Anyone found the speed sensor pin on the ECU to make the two step feature on the Ultimate. Thanks
Old Nov 20, 2005 | 07:09 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
It's behind the AC controls in that module. I am going to snap a photo of it this week. I have my Pioneer AVIC N-1 hooked up to it.
Old Nov 20, 2005 | 07:20 PM
fito's Avatar
fito
please do, the pics will help alot. Thanks
Old Nov 21, 2005 | 06:40 PM
KPierson's Avatar
KPierson
On the G35 its in a slight differnet place. Actually, its in a bunch of places.
1. The sunroof. You should be able to find the wire going up the passengers side Apillar. Remove the Apillar and strip back the tape covering the wires.
2. The radio. Removing the radio isn't even worth it....
3. The AC display in the center of the dash. Pull off the trim piece (the same trim piece that trims the analog clock). Unscrew the AC display unit and pull it out. (From memory) grab pin 4 which is a white/green wire.
I chose option 3 when I was installing my speed controlled door locking system, as it was the easiest to access, and close to where I was mounting my stuff. You can drop a wire down from the AC display right to the drivers side under dash.
I'm not sure if it matters, but the frequency of the signal is equal to twice the speed (20hz = 40mph)
Old Nov 22, 2005 | 06:16 AM
fito's Avatar
fito
Thanks man, I'll try it today.
Old Dec 11, 2005 | 08:43 PM
james840a's Avatar
james840a
Im looking for the Speed Sensor wire too, on a 350z. I read from some that its a white wire with gray bands on the AC control unit. But all i see is a white wire with pink band.
I need help.. Im installing my Nav. unit tomorrow afternoon.
Never Mind Saw a post with Pictures. It is the White wire with pink band
Old Dec 12, 2005 | 04:51 AM
KPierson's Avatar
KPierson
My info says its a straight white wire
Old Dec 12, 2005 | 08:42 AM
Sharif@Forged
Forged Performance
pin location #3. Its a white wire, with some pink bands on it...but not pink stripes.
liqalu04
Jan 2, 2022 12:58 PM
2ndchanceZ
Oct 26, 2015 08:03 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
