opinions on vortech SC
Old Nov 29, 2005 | 05:57 AM
shawn17ths's Avatar
shawn17ths
sorry for the 3 different posts, i keep thinking of different **** i want to know.... what else besides the kit should/need to buy?
Old Nov 29, 2005 | 08:31 AM
LOU's Avatar
LOU
Originally Posted by sentry65
hehe yeah that's a lot of power
still curious what your tire setup is though etc
Not many people are pushing the vortech as hard as you and Mcduck
Stock tires now (rainy season) drag radials after rain stops. 245 DR on the stock wheels. I am trying to keep my car a sleeper.
Old Nov 29, 2005 | 08:35 AM
LOU's Avatar
LOU
If you want to keep it simple, headers and exhaust. If you don't care about your car being louder you can also spring for some high flow cats or test pipes. I would also suggest a new plenum or spacer. Pretty much all of the bolt-ons compliment the Vortech.
Old Nov 29, 2005 | 10:28 AM
mcduck's Avatar
mcduck
Originally Posted by LouZer
Hahaha! I don't agree. I think my car prefers going sideways.
werd... loss of traction is dependent on how hard you launch and/or how much gas is applied. I have no problem breaking the rear end loose from a roll in 1st or 2nd just by laying on the throttle. Of course, like louZer, I'm pushing higher 300s for torque.
Oh, and since everyone else is throwing mileage figures out, I'm up to 27K miles with the Vortech installed. No major issues.
Old Nov 29, 2005 | 10:30 AM
mcduck's Avatar
mcduck
definitely go with a lightweight flywheel, great mod whether you are FI or NA. If you plan to push the power to the 400rwhp range, you probably should do a clutch upgrade at the same time.
Old Nov 29, 2005 | 10:39 AM
acg's Avatar
acg
Besides getting DR tires, is there any other way to get better traction as I like most of you cannot seem to get great take offs unless I feather the throttle, I am putting down 415rwhp and 320 of torque but cannot get the most use of the power
Would wider tires and a coilover system help?
Old Nov 29, 2005 | 10:55 AM
sentry65's Avatar
sentry65
the burninator
what type and size tires are you running?
Old Nov 29, 2005 | 11:21 AM
acg's Avatar
acg
245/35/19 up front and 265/35/19 on the rear, tires are Michelin sports.
Old Nov 29, 2005 | 02:15 PM
shawn17ths's Avatar
shawn17ths
do i need to upgrade the fuel at all?
Old Nov 29, 2005 | 02:16 PM
LOU's Avatar
LOU
You should use at least 91 octane.
Old Nov 29, 2005 | 02:18 PM
LOU's Avatar
LOU
Is that what you meant? If you are asking about the fuel system, the Vortech kit comes with everything you need.
Old Nov 29, 2005 | 02:19 PM
sentry65's Avatar
sentry65
the burninator
yeah you need wider tires, probably wider wheels too actually if you want solid traction
Old Nov 30, 2005 | 04:30 AM
shawn17ths's Avatar
shawn17ths
i didn't know the kit came with all the fuel stuff i need....and i'll be using 94 octane
Old Nov 30, 2005 | 07:38 AM
mcduck's Avatar
mcduck
It comes with all the stuff you need if you run it out of the box. If you do pulley upgrades or have lots of other mods, it's advisable to upgrade your fuel delivery system.
If you do not, you'll wind up like me... pushing lots of power, but running very high fuel pressure and over taxing the stock injectors. My next round of mods will be a return type fuel system and bigger injectors.
Old Nov 30, 2005 | 08:06 AM
shawn17ths's Avatar
shawn17ths
will i be maxin out the fuel system if i run it straight out of the box?
Old Nov 30, 2005 | 09:16 AM
hndumafia's Avatar
hndumafia
not with the stock pulley. with an upgraded pulley you run the risk of running the injectors at %100 duty, though it even seems that a lot of people have been able to run the upgraded pulley without needed larger injectors.
Old May 18, 2006 | 09:26 AM
reptile718's Avatar
reptile718
I am running 360cc injectors and a walbro fuel pump on my N/A Z at the moment, I plan to buy a Vortech kit very soon, if I upgrade the pulley will I need bigger injectors and a different fuel setup? What fuel system comes with the kit, will I need to install it already having an upgraded fuel pump and bigger injectors?
Old May 18, 2006 | 09:58 AM
  #38
sentry65's Avatar
sentry65
the burninator
hard to say, but you probably will need 440's. It depends on what other NA mods you have.
When was NA, I had around 285whp with cams and everything. I added the vortech with 3.12 pulley and need 550 injectors to maintain 460ish whp
Old May 18, 2006 | 03:16 PM
  #39
Forced's Avatar
Forced
You will be better off with our tuner kit...no fuel or engine management (less money!). Then get a computer flash from somewhere like Technosquare. SInce you already have bigger injectors and pump.
Old Jun 5, 2006 | 07:07 PM
  #40
charged's Avatar
charged
Vortech, a great mod but I wish I got the turbonetics single turbo.
