Relocating stock gagues?
Old Nov 30, 2005 | 06:51 PM
VeilsideZ33's Avatar
VeilsideZ33
Default Relocating stock gagues?
just wondering if anybody has relocated the stock gauges? Don't want to lose the OEM gauges but wouldn't mind having Boost and A/F in their place while the OEM's will sit in the A-Pillar~
-ilon.
Old Nov 30, 2005 | 08:39 PM
luanda's Avatar
luanda
Sounds interesting, but that may be quite a trick, as the circuit board that controls the three center OEM gauges is lroughly 3" X 6" mounted vertically behind the gauges...they aren't like aftermarket gauges, self-contained in a mounting cup. You may be able to solder some extended wiring between boards and the gauges and mount the circuit board remotely....would be tricky.
Old Dec 1, 2005 | 05:13 AM
Mike Wazowski's Avatar
Mike Wazowski
That would be kind of cool if you could pull it off
Old Dec 1, 2005 | 08:09 AM
VeilsideZ33
i'll keep you guys posted then~ =)
Old Dec 1, 2005 | 01:06 PM
barthelb's Avatar
barthelb
Master
The oil press and the computer are on 1 circuit, its possible to take out the Volt with out interferring with anything. I have been speaking to a company that makes guages to adapt to stock guages and read various things. They are gonna look at making one for the 350z that will read all kinds of stuff.
www.aeroforcetech.com/
sales@czp
Sep 23, 2019 03:30 PM
