Turbonetics DC headers PROBLEM!!!!!!!!
Old Dec 11, 2005 | 05:22 PM
RED HOT Z's Avatar
RED HOT Z
Default Turbonetics DC headers PROBLEM!!!!!!!!
Ok guys I am in the middle of my install and it looks like my DC headers are getting in the way. Is there anything I can do? The problem is I dont remeber where I put my stock headers at. AHHHHH so frustrated
Old Dec 11, 2005 | 05:32 PM
MIAPLAYA's Avatar
MIAPLAYA
I just replied to your PM. Honestly, take them off and find your stock ones. I think we discussed this a few times (not me and you but we as in the F/I forum) . The DC Sports MAY fit if you modify the downpipe a bit but in the end you may spool up later and they are not as strong as the stock ones are. Taurran left his on initially and later pulled them off. He spooled up like 300-500 RPMs sooner, and his car had no rattles or vibrations after removing them. Find the stockers and ditch the DCs.
Old Dec 11, 2005 | 05:36 PM
RED HOT Z's Avatar
RED HOT Z
thanks man I will do that but know to find the stockers is going to be a *****.
Do you know if there would be any problem if I just remove the left DC header and replace it with the stock one leaving the right still a DC
RED HOT Z's Avatar
RED HOT Z
RED HOT Z's Avatar
RED HOT Z
sorry^
Old Dec 11, 2005 | 05:39 PM
MIAPLAYA's Avatar
MIAPLAYA
Um yes your air flow is going to be drastically different between the two sides of the motor. I can't even begin to think of what consequences would be but its certainly not anything I would try...
Old Dec 11, 2005 | 05:40 PM
RED HOT Z's Avatar
RED HOT Z
ok I will look for them and swap both
Old Dec 11, 2005 | 05:43 PM
RED HOT Z's Avatar
RED HOT Z
Thanks Robert I am doing the install in Chino so I called my dad backa the ther house and the y found them. looks like I'm in for a long night
MIAPLAYA's Avatar
MIAPLAYA
Good call
Old Dec 11, 2005 | 05:44 PM
MIAPLAYA's Avatar
MIAPLAYA
Glad you found them, yeah I know its tough but in the end you'll be happy you did. The stock headers are not only stronger but give you a faster spool up then the DCs.
Old Dec 11, 2005 | 05:45 PM
MIAPLAYA's Avatar
MIAPLAYA
BTW if thats you in the avatar I would happily head up to Chino and give you a hand
Old Dec 11, 2005 | 05:54 PM
G352NV's Avatar
G352NV
hAHHAHAHA Me also
Old Dec 11, 2005 | 06:21 PM
D350Z10's Avatar
D350Z10
Well you have to modify the down pipe, which is pry 160 bucks worth of fabrication... but you gotta remember that with the headers although lag but more free exhaust flow compared to the restrictive stock headers and all the time spent on taking the dc's out and putting the stock ones back in... your choice but I would just recomend getting your downpipe fabricated plus it is Unique your not like everyone else.
Old Dec 11, 2005 | 07:17 PM
S12 driver's Avatar
S12 driver
But the DC may not withstand the added heat and pressure of the turbo. I think putting the stock mani on is a good idea.
Old Dec 12, 2005 | 12:29 AM
taurran's Avatar
taurran
Yeah, I ended up taking my DC Sports headers out and putting some high temp coated stock manifolds back in. I'm actually hitting boost about 700rpms sooner now. I lost about 8whp on the top end, but having a smoother faster spooling setup is worth it in my opinion. Hopefully after I get my boost controller installed this week, I'll be hitting 8.5 psi at about 2900rpms.
Old Dec 12, 2005 | 08:46 AM
MIAPLAYA's Avatar
MIAPLAYA
+100
Old Dec 12, 2005 | 08:58 AM
D350Z10's Avatar
D350Z10
True but getting your headers heat treated or wrapped is very affordable! plus clearence isn't an issue with a moded down pipe, This will always be a topic up for debate, plain and simple for some people it works and some people it doesn't.
Old Dec 12, 2005 | 10:57 AM
RED HOT Z's Avatar
RED HOT Z
Well to start off I am not the girl in my avatar she is my girlfriend.
Well anyways I already swapped the headers they were a pain in the ***!! Now i am at work and anxious to go back and complete the install.
Old Dec 12, 2005 | 11:05 AM
MIAPLAYA's Avatar
MIAPLAYA
Oh right on well you got a looker there...hang on to her... Glad you got the headers swapped. Let me know if theres anything I can do to help out.
Old Dec 12, 2005 | 11:18 AM
RED HOT Z's Avatar
RED HOT Z
I will one other thing you know the second tap on the block the one where I just have to make the thread bigger. Its not supposed to go through the block right? Its supposed to stop its just a sensor right? And how do I get all the metal shavings out of the hole? Will it be ok if I cant get all the shavings out?
