E-Manage Ultimate OR UTEC For T-Netics ST???
Old Dec 14, 2005 | 10:24 AM
  #41
Mike@Altered's Avatar
Mike@Altered
Originally Posted by MIAPLAYA
I wouldn't say that. 10 PSI was just below 100% and was able to keep AFRs in below 12 but not by much on the flash...At 9 PSI my car made 390 RWHP with 11.5:1 AFRs across. 10.5 PSI it didnt go lean till after 5k.
Not bad! We've seen a definate upward curve heading on the lean side upper rpm's at the 385-390rwhp level here. Our dyno tends to read a few hp lower than some others. Which exhaust are you running?
Old Dec 14, 2005 | 10:41 AM
  #42
MIAPLAYA's Avatar
MIAPLAYA
Apexi WS2 for right now. Most likely switching to a 3.5" split to two 3" with Apexi N1 turbo mufflers for Stage II
Old Dec 14, 2005 | 03:50 PM
  #43
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
All of these numbers are just general guidelines. Each car is going to unique, in terms of its fuel requirments and duty cycles at a given power level. I think you are both probably right!
Old Dec 14, 2005 | 04:07 PM
  #44
MIAPLAYA's Avatar
MIAPLAYA
Absolutely...no two cars are the same. My car made different numbers then the 03 test car that made different numbers then the 05 test car. All within +/- 5-10 RWHP though..
Old Dec 15, 2005 | 06:30 AM
  #45
dynamic6er's Avatar
dynamic6er
The new RC injectors for the 350Z have a redsigned nozzle, so they are safe for 90% published duty cycle, vs. the 80% usual. Just thought i would pass that along. There is always going to be a tradeoff in going with larger injectors, so bigger is not always better. I would chose an injector that meets your needs, plus a little extra.
The Tnetics comes with Denso drop ins right?
Old Dec 15, 2005 | 06:41 AM
  #46
nissansource's Avatar
nissansource
not sure but it did have a different pattern
Old Dec 15, 2005 | 07:20 AM
  #47
taurran's Avatar
taurran
yup
NissanZcrazy
Nov 2, 2015 06:03 PM
2ndchanceZ
Oct 26, 2015 08:03 PM
Depravity
Oct 1, 2015 04:49 PM
z33z_nutz
Sep 23, 2015 07:22 PM
