serious clutch comparisons
Old Jan 3, 2006 | 06:30 AM
MoodDude's Avatar
MoodDude
Originally Posted by overZealous1
well after tons of research i am leaning towards the rps 6 puck set up with rps adjustable pressure plate and sprung hub 6 puck disk. i have seen a few places you have to use this with the rps flywheel, then heard that it can be used with the stock flywheel also. need to talk to rps personally to make sure on this. they may just have a new set up that can be used with the stock flywheel.
The shop I uses sells all ATS and RPS products. They recommend the RPS Max street over the others due to:
Price
Life of clutch
Drivablity
They said that from their exerience that the 6 puck on the Z wears out faster than the Max street. If money is not an issue than they said go with ATS.
I just bought mine and am waiting to recieve it.
Old Nov 9, 2006 | 02:22 AM
Pilot_Z's Avatar
Pilot_Z
overZealous1-
Did you end up getting the RPS?
Impressions?
Old Nov 9, 2006 | 05:52 AM
002-M-P's Avatar
002-M-P
I have the RPS on my car and I really like it...no slipping for me...23k miles on it with over 400whp (around 10k of which were over 450whp). Audible Mayhem seems to have had a different experience with it slipping though close to 500whp. So, I would say it is a great clutch if you don't mind a really stiff clutch that is pretty grabby and you have less than 500whp (aka non-built motor). Still great clutch and I won't replace it until I build my motor.
Old Nov 9, 2006 | 05:55 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Curious what do you plan on running clutch wise after the motor build?
Old Nov 9, 2006 | 11:56 AM
002-M-P's Avatar
002-M-P
Well right now....the when and even still IF I build my motor isn't known. If everything goes the way I want...it will be a ATS twindisc with the heavy pressure plate. But who knows, if money is tight (which it probably will be), I may keep the RPS until it slips, then replace it.
Old Nov 10, 2006 | 06:05 AM
DSport G35's Avatar
DSport G35
Here are some pics of my Carbonetic(new ATS brand) Triple Carbon Clutch 1350kg and heavy flywheel. This clutch is a highly engineered piece and the nicest clutch I have ever seen.
Old Nov 10, 2006 | 06:24 AM
002-M-P's Avatar
002-M-P
don't show me those pictures....its too beautiful and now I want one
Old Nov 10, 2006 | 06:39 AM
QuadCam's Avatar
QuadCam
"yes the act 6 puck is sprung hub" and another says "no the act 6 puck is not sprung hub" and both come up with different tq holding capacities too for the same clutch!
that is because ACT has both a sprung hub 6 puck and an unsprung 6 puck.
They are both listedas holding 582 ft-lb of torque.
Parts numbers are:
NZ1-HDG6 for the sprung 6 puck
NZ1-HDR6 for the unsprung 6 puck
sherm
Apr 11, 2020 05:21 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
