AEM wideband not reading!!! Car detonating!!!
Old Dec 19, 2005 | 09:31 AM
RED HOT Z's Avatar
RED HOT Z
Well since I bought it at GT Motorsports they said they would either fix it or swap it out for me. I was thinking maybe I am running way to rich it isnt reading.
Old Dec 19, 2005 | 09:33 AM
nissansource's Avatar
nissansource
No at Idle it will be lean only WOT it will richen up. also it will read to 9 and if your car was at 9 then it wouldnt even run like it did =) cool show GT motorsports when you got time
Old Dec 19, 2005 | 09:39 AM
RED HOT Z's Avatar
RED HOT Z
I am taking it in at noon.
Did you call T-netics?
Old Dec 19, 2005 | 10:13 AM
nissansource
I havnt called TN ill be contacting them later
Old Dec 19, 2005 | 10:21 AM
RED HOT Z's Avatar
RED HOT Z
they said all you can do is reflash the ecu but I am not sure if I trust that.
Old Dec 19, 2005 | 10:23 AM
nissansource
thats what they said but TS tells me different
Old Dec 19, 2005 | 10:26 AM
RED HOT Z's Avatar
RED HOT Z
I think I might just take it to GT they said they will look over my install fix the air leak on the plenum fix or swap the aem wideband and dynotune my car. I was planning on doing it eventually might as well do it now.
Old Dec 19, 2005 | 10:47 AM
nissansource
are they going to work on your car today while you are there? if so mind if i join? id like to meet the guys down there anyway since they are a local business to me
Old Dec 19, 2005 | 12:00 PM
RED HOT Z's Avatar
RED HOT Z
I will definately call you and let you know I am going to go drop it off right now
Old Dec 19, 2005 | 12:02 PM
RED HOT Z's Avatar
RED HOT Z
maybe when they do the dyno you can bring your camera
Old Dec 19, 2005 | 12:08 PM
nissansource
Sounds good.... let me know ill head over
Old Jan 2, 2006 | 02:26 PM
350zzzzzz's Avatar
350zzzzzz
3 lines means you are off the scale either way. Chances are you are running 17:1 at that point. at 10:1 the car would just bog because it's too rich. You are most likely way too lean.
Old Jan 2, 2006 | 03:57 PM
KTaylor's Avatar
KTaylor
Originally Posted by RED HOT Z
If I get the UTEC and have it dynotuned will it fix the AFRand the detonating?
yes this exact thing happened to my brothers car and it really messed it up when he got inot boost. but now hes got bigger injectors and its getting tuned witht the utec tomorrow so i think it will be fixed. we have a base map on now with the utec and its already running alot better and the aem wideband is working right now too.
Old Jan 16, 2006 | 10:15 PM
Ant830's Avatar
Ant830
Quick question.......my greddy TT was detonating yesterday at around 4k-5k rpms after a ****TY TUNE but the engine should be ok after it detonating like that as long as I stay outa boost? Man I'm so scared of my engine going....
Old Jan 16, 2006 | 10:34 PM
XBS's Avatar
XBS
Veteran
if your engine does go, ill have a spare longblock for sale
Old Jan 17, 2006 | 07:29 AM
Ant830's Avatar
Ant830
I went w/ stock boost to prevent me from spending more money on the engine. I really don't want to throw anymore money into it.
Chris350z03
Oct 8, 2023 07:19 PM
etkms
Jun 19, 2022 06:30 PM
aarrgghh
May 1, 2022 11:04 AM
Calinismo350z
Sep 14, 2015 04:04 PM
speedsniper
Sep 14, 2015 08:46 AM
