AEM wideband not reading!!! Car detonating!!!
Old Dec 18, 2005 | 09:07 PM
RED HOT Z's Avatar
RED HOT Z
Default AEM wideband not reading!!! Car detonating!!!
Ok guys so I installed the AEM wideband one wire goes to 12v wire and the other is a ground. Then I hooked up the sensor to the 3in turbonetics exhaust pipe at the very end where there was already a whole. I dont understand it doesnt even read any numbers it lights up but thats about it.
Also my car is detonating I can hear the noise between 3-6K rpms in 3rd gear.
What do I do!!!!
Old Dec 18, 2005 | 09:11 PM
tig488's Avatar
tig488
you park that **** until you get it looked at.
Old Dec 18, 2005 | 09:24 PM
DBZ33's Avatar
DBZ33
What do I do!!!!
Take it easy on the car. Don't put it in boost. That is where my car was running lean. Take it to a shop with a dyno and check the AFR.
Attached Thumbnails AEM wideband not reading!!! Car detonating!!!-leandyno2.jpg
Old Dec 18, 2005 | 10:50 PM
RED HOT Z's Avatar
RED HOT Z
If I get the UTEC and have it dynotuned will it fix the AFRand the detonating?
Old Dec 18, 2005 | 10:53 PM
mistaboosta's Avatar
mistaboosta
what do you mean by saying it doesn't read? It shows 3 lines on the LCD panel?
Than it means u r running über rich.
Old Dec 18, 2005 | 10:57 PM
DBZ33's Avatar
DBZ33
Yes thats what I am doing right now. Before you spend money on the UTEC go and run it on a dyno with an wideband just to be safe.
Old Dec 18, 2005 | 11:00 PM
RED HOT Z's Avatar
RED HOT Z
yup shows nothing just 3 little lines
Old Dec 18, 2005 | 11:02 PM
RED HOT Z's Avatar
RED HOT Z
o and the money is no problem I just want to be safe you know rather spend money and have peace of mind
Old Dec 18, 2005 | 11:04 PM
DBZ33's Avatar
DBZ33
I know what you mean. Go with the UTEC. You will be happy.
Old Dec 18, 2005 | 11:08 PM
RED HOT Z's Avatar
RED HOT Z
I got offered to have a UTEC installed and dyno tuned for 1300 is that a good deal?
Old Dec 18, 2005 | 11:15 PM
DBZ33's Avatar
DBZ33
Yes I would say that is a good deal. The UTEC is around $950 and the map sensor is $100. Labor for install and tuning would be in the $300 - $500 area. I would do it. I also went with there wideband O2. Its $399 but it plugs right into the UTEC and you can also data log from it. Just be carfull until you get the UTEC. Don't go into boost. Good luck and I hope you get your car running strong and enjoy it.
Old Dec 18, 2005 | 11:17 PM
RED HOT Z's Avatar
RED HOT Z
thanks alot bud I cant wait to stomp on it
Old Dec 18, 2005 | 11:24 PM
DBZ33's Avatar
DBZ33
Believe me I know what you mean. I still haven't had a chance to floor my car yet and my kit was installed Nov. 20th. I waited till the UTEC was out. Now I am just waiting for my installer.
Old Dec 18, 2005 | 11:25 PM
RED HOT Z's Avatar
RED HOT Z
good luck to you
Old Dec 18, 2005 | 11:27 PM
DBZ33's Avatar
DBZ33
Thanks. Same to you.
Old Dec 19, 2005 | 04:41 AM
taurran's Avatar
taurran
As stated, limp the car to a local dyno and run the car with an AFR graph. In the process you'd probably want to have your shop double check your install and your Wideband install.
Even with the reflash on this kit, I would not recommend running the car without first dynoing it. I would in no way recommend that for ANY new FI installation.
Old Dec 19, 2005 | 06:43 AM
ht4's Avatar
ht4
+10000 on taking it to a dyno w/wideband to have it checked out.
I thought that three lines on the AEM meter meant that the AFR was below 10... That should not be detonating...
Old Dec 19, 2005 | 07:07 AM
nissansource's Avatar
nissansource
Hey Red Hot yes the Utec will fix your car. But like i told you lets call AEM and Turbonetics tomarrow. Sucks i know how you feel just want to throw all the money at it and what not hell i do the same but chill out for a second and lets call the right people. Tell turbonetics theres not 1 but a few cars out there with lately installed kits detonating. if they want they can take Mine and yours up there and leave it for a few days. btw yours was detonating way more then mine was and you just have exhuast.
Old Dec 19, 2005 | 09:17 AM
RED HOT Z's Avatar
RED HOT Z
Hey Doug I will call them right now and I called AEM and they said I dont have to touch the back just plug and play so something must be wrong.
Old Dec 19, 2005 | 09:19 AM
nissansource
ask AEM if you can take it to them and swap it out i really dont know how you coulda installed that sucker wrong
