Can UTEC adjust idle?
Old Dec 20, 2005 | 12:53 PM
Nismo350ZRT's Avatar
Nismo350ZRT
Default Can UTEC adjust idle?
I want to run JWT cams on my 05 but I don't want a crappy idle. Anybody know?
Old Dec 20, 2005 | 01:01 PM
D350Z10's Avatar
D350Z10
Yes I am 95% sure it can, I know that it can change you rev limiter.
Old Dec 20, 2005 | 01:04 PM
dynamic6er's Avatar
dynamic6er
Not currently. The dealer can flash for higher idle.
You can also use this JWT mod. It has worked really well for alot of the cars here.
http://www.jimwolftechnology.com/wol...BILITY_FIX.PDF
Old Dec 20, 2005 | 01:14 PM
paranormal's Avatar
paranormal
Evil Boy 4 LIFE
is your 05 the rev-up motor? if so your wasting your money putting jwt cams in it
Old Dec 20, 2005 | 01:30 PM
Nismo350ZRT
Originally Posted by dynamic6er
Not currently. The dealer can flash for higher idle. You can also use this JWT mod. It has worked really well for alot of the cars here.
I really don't want to pay for a flash if I'm already paying $$$ for the UTEC. I asked before about the JWT idle mod but didn't get any responses so I assumed it wasn't that effective.
No, I have the 287 engine.
Old Dec 20, 2005 | 01:35 PM
dynamic6er's Avatar
dynamic6er
Sorry did not see your posts before. We have a built motor APS car with JWT cams and ATS carbon clutch car that we built for a customer. Before the JWT mod it would stall all the time and fluctuate all the time. Now its rock solid. We also have a couple of customers with a rough idle just generally that have basic mods and this cures the issue instantly.
Old Dec 20, 2005 | 01:51 PM
Nismo350ZRT
That's excellent! Thanks man! Looks like I'll be getting the JWT cams, idle adjustment kit and UTEC.
Old Dec 20, 2005 | 02:37 PM
booger's Avatar
booger
The idle JWT kit you talk about , is that the one that T's off the vacuum line going to the Throttle body and runs to the breather hose hooked up on the intake ?
Old Dec 20, 2005 | 02:38 PM
plumpzz's Avatar
plumpzz
The dealership should flash it for relativly cheap.. probably same price as JWT mod.. once UTEC gets idle adjustment the JWT fix would be useless splicing imo. Why not get the dealership to flash it using consult?
Old Dec 20, 2005 | 03:02 PM
Nismo350ZRT
From what I've read, you can't adjust the idle on 04.5+ using the consult.
Old Dec 21, 2005 | 06:54 AM
dynamic6er's Avatar
dynamic6er
Yep. T in the line between the EVAP Purge Valve and the Plenum (behind the Throttle Body. The T connects to the Crankcase Breather Hose.
Old Dec 21, 2005 | 07:03 AM
theking's Avatar
theking
Won't this send the pressurized air when under boost out of the intake manifold and out the intake tube, basically a vacuum leak?
Old Dec 21, 2005 | 07:43 AM
dynamic6er's Avatar
dynamic6er
Yes a little bit. Thus far we have not noted any issue becasue its such a small orrifice, but a check valve could be added between the T and the Breather Hose to enure against this under boost.
Old Dec 21, 2005 | 08:07 AM
theking's Avatar
theking
Good idea.
Old Dec 21, 2005 | 10:43 AM
hurahn's Avatar
hurahn
That's my car he's talking about and yes it idles perfectly now. Before, it idled like an old american muscle(I'm assuming that because I've never ridden in an old modified muscle car) but now it's like stock. No need to raise the idle.
Old Mar 22, 2006 | 05:51 PM
bverschage's Avatar
bverschage
I think that I am having this issue with the unsteady idle due to cams. But, the line that you tap into from the back of the throtle body, I already have tapped into for a fuel regulator. Has any one done this and had any problems?
Old Mar 22, 2006 | 08:16 PM
backagain's Avatar
backagain
sorry to be off subject but does anyone find it funny that there is a face in the picture of the plenum
Old Mar 22, 2006 | 08:31 PM
Alberto's Avatar
Alberto
Cranky FI Owner
^^ Lol good find.
Old Mar 22, 2006 | 08:38 PM
backagain's Avatar
backagain
Originally Posted by Alberto
^^ Lol good find.
thanks
Old Mar 22, 2006 | 09:03 PM
bverschage's Avatar
bverschage
So I did the install of the JWT kit, and the car is still running like but. I let the car warm up and then took it out and it stalled 3 times in the 1st 5 min. The idle is still very rough, though it has gotten a little better as I have driven the car. After it stalled the 3 times it do not stall after that. But, my fuel pressure is stuck between 2.8 and 2.9, is this normal? How long does it take for the ECU to learn the new AIR/FUEL? And is my fuel pressure suck due to the increase in vacuum?
