350x turbo check engine light on!!
Old Dec 20, 2005 | 06:28 PM
ryan350zpower's Avatar
ryan350zpower
Default 350x turbo check engine light on!!
so, im at my girlfriends house.... i get in my car... start it. back up in reverse and then...BAMN the light came on... i cant believe it. never had one before or after the turbo was installed.... MIAPLAYA is trying to help me out.... im a little worried. i hopoe everything is ok.
Old Dec 20, 2005 | 06:30 PM
Jokestrap's Avatar
Jokestrap
Hook it up to a comp to read the outputs. It is most likely due to cat removal.
Old Dec 20, 2005 | 08:22 PM
ryan350zpower
ive had this turbo on for like 7000 miles on it and no problems ever... and im using a high-flow cat
Old Dec 20, 2005 | 08:30 PM
taurran's Avatar
taurran
Take it to an autozone and have them use an obd scanner. It will tell you the code.
I will bet $$$ that it will be gone before tomorrow morning. It's almost definitely the "Multiple cylinder misfire" code that is common with FI on these cars. If it happens from time to time, it's nothing to worry about. I've had mine go off randomly about 3 times in the past 7 months since the kit was installed. It lasts for about an hour and then clears when you start the car the next time.
Old Dec 20, 2005 | 08:48 PM
plumpzz's Avatar
plumpzz
I think your ecu found out you have turbo!
Old Dec 20, 2005 | 09:02 PM
AmyCroft's Avatar
AmyCroft
Smile Where ?
Where is your CAT? TN single turbo
Old Dec 21, 2005 | 08:18 AM
MIAPLAYA's Avatar
MIAPLAYA
+1 to what was said. Most likely an 0300.
Old Dec 22, 2005 | 05:33 AM
ryan350zpower
0300 thank god.... it wasn't anything serious... when that light came on, i was ****ting myself.... thanks guys for your help...
Old Dec 22, 2005 | 04:41 PM
Jokestrap's Avatar
Jokestrap
I believe "high flow cats" are very different than "cat deletes" (straight pipes, no cats). It completely changes the backpressure readings without the cats.
Old Dec 23, 2005 | 02:04 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Welcome to the 0300 club. The club has pretty high turnover...its like a revolving door of sorts.
Uriyo_
Sep 8, 2021 08:46 AM
350z82
Oct 1, 2015 06:25 PM
