JWT Cams and Boost Big Gains?
Old Dec 21, 2005 | 10:57 AM
XBS's Avatar
XBS
Veteran
Default JWT Cams and Boost Big Gains?
I am wondering if JWT cams make a big diffrence on boosted VQ35s, How much more power would you gain running around 10psi on a 9.0:1 compression ratio block with forged internals? Just trying to see if it is worth justify the cost. Thanks!
Old Dec 21, 2005 | 11:23 AM
plumpzz's Avatar
plumpzz
Im in the same boat as you.. My reason for gettin cams is same power at less boost and so that my car doesn't fall on its face after 5.5kRPM.
Old Dec 21, 2005 | 11:29 AM
SinCity350Z's Avatar
SinCity350Z
Track Whore
I have heard of 30-50whp with the JWT TTs. I think that was on a built motor though.
Old Dec 21, 2005 | 11:37 AM
roncfpz's Avatar
roncfpz
I'm pretty sure Sharif mentioned about 40whp from cams when I posed the same question. However, that was with a stock motor.....not sure about built motor with lower compression.
Old Dec 21, 2005 | 12:34 PM
dimebagdolf's Avatar
dimebagdolf
Hey Guys,
I went with the JWT Cams at the suggestion of Rob at Z Car Garage, and he estimated that I saw about an additional 40whp from the cams.
Old Dec 21, 2005 | 12:36 PM
dirtroad's Avatar
dirtroad
Originally Posted by dimebagdolf
Hey Guys,
How much did that cost you, roughly?
Old Dec 21, 2005 | 12:51 PM
mikz350's Avatar
mikz350
Exclamation
so if i add 2 psi of boost i gain 40whp and i save 1500+ camshaft install
but correct me if im wrong tro
Old Dec 21, 2005 | 12:53 PM
SinCity350Z
Track Whore
Ahhh, but if you add 2psi and cams you have 80whp...
Old Dec 21, 2005 | 12:54 PM
mikz350's Avatar
mikz350
sa all add 4 psi then! and still save 1500$$$$$$++++
Old Dec 21, 2005 | 12:59 PM
XBS's Avatar
XBS
Veteran
point is with the cams you will always have roughly 40whp more at any givin boost setting. safer way to get more power out of the motor
Old Dec 21, 2005 | 01:08 PM
dimebagdolf
I'm sworn to secrecy on the price I paid for the cams, but the pricing was great for both the parts and labor.
Old Dec 21, 2005 | 02:00 PM
mikz350's Avatar
mikz350
i would say sc +camshaft would be nice combo troo
Old Dec 21, 2005 | 02:14 PM
GMADD's Avatar
GMADD
Would the Tomei 264 be a better choice over the JWT cams ?
I'm also thinking of doing cams in spring, but not sure if it's worth the extra labour.
I have my ECU tuned by TS, would I need to tune it again after the install ?
Tasso-
Old Dec 21, 2005 | 02:17 PM
SinCity350Z
Track Whore
I don't know much about the Tomei cams, but I do know that JWT puts out superior quality parts so I don't think you can go wrong with them.
I would definately get my ECU re-tuned after the cams if I were you.
Old Dec 21, 2005 | 02:38 PM
nissansource's Avatar
nissansource
yes the cams will do great its what im going to install here in a couple of days
Old Dec 21, 2005 | 02:45 PM
GMADD's Avatar
GMADD
So you guys are saying that it's worth the $$$$ for cams ?
Does anyone have more info on the Tomei cams ?
Old Dec 21, 2005 | 03:37 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Upgraded cams will allow you to run more power at a given boost level. This is almost always a good thing. Cams also reduce the thermal load on the motor.
From experience, we usually see about 30-40whp improvements, at a given pressure level. You also shift the power band about 500rpm to the left, which allows the engine to produce power nearly to redline, assuming you have a zero backpressure exhuast system.
Old Dec 21, 2005 | 03:47 PM
GMADD's Avatar
GMADD
Sharif have you had any experiences with the Tomei cams on the VQ35 ?
Tasso-
Old Dec 21, 2005 | 03:57 PM
XBS's Avatar
XBS
Veteran
What do you think the back pressure will be like with a HKS true dual exhaust and test pipes? also what is the diffrence between just doing cames and doing cams and springs
Old Dec 21, 2005 | 04:20 PM
ImportPartsPro's Avatar
ImportPartsPro
Vendor - Former Vendor
Tasso-
I have done the Tomei cams on several cars and they are more aggresive then the JWT. More aggressive = more power
I strongly recommend the Tomei and the Ferrera Valve train for anyone shooting for 650 Rwhp and beyond.
