Weak Link - Head Gasket
Old Dec 23, 2005 | 11:26 PM
Philthy's Avatar
Philthy
Boost Junkie
My motor is sleeved, so that doesn't cure the problem - it may have helped, but it's not good enough.
I'm going to be experimenting with different head gaskets - it's just such a pain in the **** to change the gasket!
Old Dec 24, 2005 | 07:20 AM
g356gear's Avatar
g356gear
What size did you bore your new sleeves out to?? Bigger than stock? Another option might be to go to the thicker sleeve with a smaller piston bore size.
Old Dec 24, 2005 | 08:24 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Originally Posted by BlackTuner
Has anyone thought about having the bolt holes being drilled and tapped to accept thicker rod bolts?
Jermaine~
Performance Motorsports uses oversize ARP head studs, which, IIRC are 9/16 in diameter. Certainly doable, but still doesnt answer the question if the ARP hardware is backing out.
Old Dec 24, 2005 | 08:39 AM
g356gear's Avatar
g356gear
May have to go to a locking type of stud/nut to keep things from backing out.
Old Dec 24, 2005 | 09:34 AM
Sharif@Forged
Forged Performance
The nut isnt physically backing out. But with repeated heat cycling, there is a possibility of some stretch, and a decrease in preload. In this case, a locking nut/washer wont help.
Ideally, ARP recommends retrqing the heads, but we all know that's not feasible, because the cams have to removed to access the nuts.
Old Dec 24, 2005 | 09:46 AM
Philthy's Avatar
Philthy
Boost Junkie
.20 over bore - nothing big and this isn't the problem... this has occurred to every car, liners, sleeves, stock.
The latest theory is the block and heads, although are both aluminum, may be different types and their heating/cooling properties maybe different… A thicker head gasket would probably help if this is the true.
burglapfd
Dec 6, 2020 01:04 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
