What mod to do next after TN install
Old Dec 27, 2005 | 07:26 PM
craigo'sznprgrs's Avatar
craigo'sznprgrs
Exclamation What mod to do next after TN install
First of all, I am still awaiting my ecu to complete my install, no worries, should have it Thurseday or Friday. Next, I am considering either a custom 3" exhaust, but turbonetics informed that may cause the boost to raise too high for the standard reflash, I also considered the motordyne 5/16 plenum spacer, Turbonetics said no real issues there, what is everyone's feedback? what are some realistic horsepower gains? I do plan to purchase the utec in a few months, but what about mods before utec? Any advice will be great. On a seperate note, I will get the car dynoed later next week, but the numbers will be real low, because of the dyno they use, you can check it out at www.dyno4mance.com, to see the dyno and some pretty cool videos, under the toyota section is my old 4runner, check out how low the numbers were, that truck did a 9.6 in a 1/8 mile at 77 mph, I think it had a little more than 228.3 hp, personally
Old Dec 27, 2005 | 07:29 PM
D350Z10's Avatar
D350Z10
Go witha UTEC brother... 5 map settings you can always choose the power you want to run!!!!!!!!!
Old Dec 27, 2005 | 07:33 PM
craigo'sznprgrs
Yea, I want the utec, still in for the group buy? I have almost convinced myself, but checking with my supplier first to see what price that I can get
Old Dec 27, 2005 | 07:45 PM
D350Z10's Avatar
D350Z10
Sounds good.. let me know asap if possible!
Old Dec 27, 2005 | 09:11 PM
MIAPLAYA's Avatar
MIAPLAYA
Motordyne 5/16" plenum spacer is a great mod...I have it on my car and definitely felt a difference in the mid-range as far as power...no good dynos yet though. Hopefully soon.
Old Dec 28, 2005 | 04:50 AM
Midnyte's Avatar
Midnyte
I put the spacer and the Fuji exhaust on mine. TN claims their reflash is good (they tested) until 9.5psi. Out of the box your probably right at 8psi. After my plenum spacer, kinetix plenum, fujisubo exhaust, and lightweight crank pulley...it only raised my boost to 9psi. You should be fine. My boost contoller goes in this weekend and I may raise it the other .5
BTW IMHO I would get the exhaust before you get the EU or UTEC so you dont have to tune it twice.
Old Dec 28, 2005 | 05:36 AM
craigo'sznprgrs
Cool, so do the mods, then get the eu or utec. Sounds good to me, also which exhaust has the largest diameter or would you just simply go with a custom made 3"?
Old Dec 28, 2005 | 05:40 AM
Alberto's Avatar
Alberto
Cranky FI Owner
I went with a JIC single 80mm full Ti. Its actually a little over 3" as I believe 76mm is 3". And btw it only weighs 9.8lbs so you take some weight back you added with the kit. Any of the JIC 3", Tanabe and Apexi 2.75"-3" will work well for you...
Old Dec 28, 2005 | 05:56 AM
craigo'sznprgrs
do you have a good supplier or a pic of how it looks, it is a single cannister right? I would like to see what it looks like on a Z.
Old Dec 28, 2005 | 06:03 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Yes its a single canister. I have seen it in person. Honestly the pics online dont do it justice, judging from the pics I thought the canister was too small, but its not. I got mine from Steve @ Evolution for a great price. I can take pics if you want, but it wont be on the car till hopefully Saturday when I might be finishing the install of my kit...caution though, I have heard it is LOUD. I got the non-resonated version
Old Dec 28, 2005 | 06:04 AM
BluZee's Avatar
BluZee
Is there any difference, performance wise, between your new 3" single exhaust and making your old dual exhaust work with the ST?
Old Dec 28, 2005 | 06:16 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Prolly not, but I am tired of the Injen, the resonators are dented and scratched to hell because they hang so low, and after many adjustements it still bangs around, also one of the pipes has been replaced because I drove into the city hit a pot hole and put ahole right in the pipe breaking off one of the hangers, lol. It was just time for a change, and I wanted a Ti exhaust...
Old Dec 28, 2005 | 06:23 AM
BluZee's Avatar
BluZee
Thanks for the reply. I have the straight tip Injen and would like to go Turbonetics ST one day.
Im looking forward to seeing your setup and track times.
Old Dec 28, 2005 | 06:36 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Thanks, yeah the Injen is fine, dont let the duel 2.25" pipes fool you. Two pipes that size flow well wnough for almost 500whp. I remember the guy from MRC running an APS TT kit with an Injen, trapping nearly 120mph with that exhaust around 450whp. No need to change it, just mod it like you said.
Old Dec 28, 2005 | 06:41 AM
BluZee's Avatar
BluZee
I didnt think that there would be anything wrong with it, but wasnt 100% sure. Thanks again.
Old Dec 28, 2005 | 06:42 AM
Alberto's Avatar
Alberto
Cranky FI Owner
No problem
Old Dec 28, 2005 | 08:00 AM
Zivman's Avatar
Zivman
Is this what you guys call 2.25" piping? This is my pic I took of an injen I pulled off a guys car. It is maybe 1 7/8" OD piping. VERY SMALL
In regards to this thread, I would go with the plenum mod. And do the exhaust when you get a tunable EMS.
Old Dec 28, 2005 | 09:09 AM
BluZee's Avatar
BluZee
LOL!!
Old Dec 28, 2005 | 09:31 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Well I believe the outside diameter is 2.25" - at least thats what Injen claims. Regardless, this exhaust has been proven to not be a restriction up to about 450whp like I stated. The guy running this exhaust had dyno numbers and trap speeds as good or better than others running true 2.5" exhausts, take it for what its worth.
Old Dec 28, 2005 | 10:05 AM
Zivman's Avatar
Zivman
I am not making any claims on the flow of the exhaust. I just thought the piping looked very small when I pulled the exhaust off, so I asked the owner what it was and he responded 2.25" piping. I just pulled out the tape measure and was blown away at what I saw, so I had to take a pic
