ATI Pro Charger Number
Old Mar 28, 2006 | 03:19 PM
  #41
palmerwmd's Avatar
palmerwmd
Dyno Sheet with 9 psi Mods listed
http://forums.freshalloy.com/ubbthre...o=&fpart=&vc=1
Fred...
Old Mar 28, 2006 | 03:38 PM
  #42
booger's Avatar
booger
Fred...
Getting very lean up top and you didnt even go to red line . Looks a little un- safe , Dyno only goes to a little passed 5900rpm and your above 12 to 1 A/F
Old Mar 28, 2006 | 05:06 PM
  #43
palmerwmd's Avatar
palmerwmd
True,
Actually the rpms read 200 rpm low so itr went to 6100, even so I had AAM flash my redline <down> for a while for safety
Thats the reason why I am not on 9 psi Pulley anymore.
Need a better fuelsolution for "9psi" Pully.
Likely going with fuel return This summer ,so I can go back to 9 psi pully and feel safer about it.
Old Mar 28, 2006 | 05:46 PM
  #44
Julian@MRC's Avatar
Julian@MRC
True,
Dude, WAY unsafe!! Looks like your out of injector or fuel pump..Go with 440cc's and a return system and a UTEC over that reflash..We just did a procharged car the other day with a UTEC and stock exhaust that made 350whp and stayed in the low 11's A/F..
Old Mar 28, 2006 | 06:07 PM
  #45
palmerwmd's Avatar
palmerwmd
Guys, I am no longer on 9 psi Pulley.
So I am not running lean anymore.
Low to mid 11's except at redline of ( back up to) 6600 rpm which is 12.0, all others including 6500 are in 11's.
With my 7 psi Pulley
Fred..
Old Mar 29, 2006 | 01:20 AM
  #46
blkness's Avatar
blkness
Hey guys Im not here much more on the G forums...
I just picked up an ATI (used) its been about a month or 2. I love every minute of it. Running RC440cc, with Greddy EU got it tuned by Shawn at Churches he as usual did a great job. I had a bad exhuast leak when we did the run though so I might go back for a check up Saturday.
7.5lbs of boost I put down 382hp 322tq. I know my tq numbers came up since i fixed the leak I dont know about the hp though.
Im having a lot of problems with my big cog belt being loose though. Anyone got any tips. Its a brand new belt but its just too loose. Any help would be great.
Old Mar 29, 2006 | 09:04 AM
  #47
chrisle7220's Avatar
chrisle7220
If the belt isnt slipping at all, then you should be fine.
Old Mar 29, 2006 | 11:39 AM
  #48
blkness's Avatar
blkness
It slipped on the Dyno we fixed it and its been fine i havent felt it slopp on the road but who knows.... Also what you guys doing about filers. That screen is pointless unless you're worried about sucking up a bird.
Sorry if im going off topic but this board seem to be the only ones who help and know
Old Mar 29, 2006 | 08:17 PM
  #49
Ep3's Avatar
Ep3
what other mods you got bro?
on the 7 lb pulley i hit 9.6 psi of boost acording to the dyno and my defi gauge
Old Mar 29, 2006 | 11:59 PM
  #50
blkness's Avatar
blkness
I have motordyne 1/2" spacer, test pipes, Borla, Greddy EU, Rc440cc...
Im re-dynoing Saturday I think I might be up to like 350tq.
Old Mar 30, 2006 | 05:45 AM
  #51
trefling's Avatar
trefling
If you put the 44 tooth drive cog wheel the blower will make between 15-18psi. The ATI procharger has allot more in it than most people think.
_bit
Oct 2, 2015 07:49 AM
