Vortech SC people....
Old Jan 3, 2006 | 08:25 AM
chimmike's Avatar
chimmike
Default Vortech SC people....
Just got some questions for you.
Happy with the kit?
How many use the SS box that comes in the kit?
is the SS box tuneable?
How reliable has your setup been? If kept at stock boost, of course
Any other pertinent information would be great.
I ran a few searches and info was kinda sparse.
Old Jan 3, 2006 | 08:49 AM
ZU L8R's Avatar
ZU L8R
Viper Sellout
Happy with the get going with the 3.12 pulley on Thur. No SS box here. Get the tuner kit and a UTEC or EU and a Walboro 255 and injectors. Way better setup for the same $$$
Old Jan 3, 2006 | 09:01 AM
Zquicksilver's Avatar
Zquicksilver
+1... that's my plan ^ peace of mind on a daily driver!
Zquicksilver
Old Jan 3, 2006 | 09:06 AM
booger's Avatar
booger
It depends on your goal for the kit is . If you plan on keeping the kit as is . The kits is good to go
Old Jan 3, 2006 | 09:09 AM
chimmike's Avatar
chimmike
basically, just assuming the SS box keeps the a/f in check, I'd most likely keep it at stock boost. I've got experience with tuning for a/fs and what not, but I don't want to deal with all that on this as a daily driver. Just plug 'n play, and go.
Anyone have the cheapest location to purchase this from? Found it on mynismo.com but most vendors don't carry it.
thanks for the help so far
Old Jan 3, 2006 | 09:23 AM
LOU's Avatar
LOU
I still have the SS box, but I droppped the FMU and aux fuel pump for the Walbro 255lph, bigger injectors and a one-of fuel system. As booger said, if you plan to stick with stock boost, the kit is good to go. The A/F is a little rich, but safe.
You might want to try Avalon Racing. They always have good prices.
Old Jan 3, 2006 | 09:42 AM
chimmike's Avatar
chimmike
well honestly, I want between 380-400whp. I've heard anything more than that is unsafe on stock internals. I figure I'd have to upgrade the pulley for that?
but also, it's not like I'm running stock exhaust. I'm also about to throw on the 5/16" isotherm spacer.
Old Jan 3, 2006 | 09:43 AM
booger's Avatar
booger
The kit will work , but you'll need the smaller pulley and tuned by some one that knows what they are doing...to get 380whp
Old Jan 3, 2006 | 09:48 AM
chimmike's Avatar
chimmike
so what's usually seen outta the box? closer to 350whp or so?
so if that's the case, I need to ditch the SS box and get the tuner kit or can I actually tune the SS box?
Old Jan 3, 2006 | 10:00 AM
amai21's Avatar
amai21
I have the Vortech with the SS box that was dynotuned. I am pushing 374rwhp on all stock. No larger injectors either. Out of the box the SS box was completely off. First run I pushed 280rwhp
Old Jan 3, 2006 | 10:38 AM
LOU's Avatar
LOU
I got 365rwhp out of the box with plenum, headers and exhaust.
LOU's Avatar
LOU
Old Jan 3, 2006 | 11:24 AM
booger's Avatar
booger
The SplitSec Box is VERY tunable . JWT TT kit runs the SS Box . VRT tunes the JWT TT kit with it and have several cars on this forum running big WHP . So running the Vortech kit with the 3.12 pulley and making 380whp is very doable and reliable .
I've gone the whole 9 yards with this kit and made a bunch of mistakes . Dont spend a bunch of money you dont need to . If you want this kit . Get it , have it installed with the 3.12 pulley . Have it tuned by some one that knows and has the R4 program to tune the SS box . Drive it for a awhile and see if its enough and to see if the car likes it . Then if you want to add more power , you will know more about F/I , the Vortech kit , and what exactly you'll need to up the power ......Bill
Old Jan 3, 2006 | 11:36 AM
chimmike's Avatar
chimmike
Thanks a lot for the help. So the stock kit doesn't come with the 3.12 kit so I'll have to order that.
I'll contact SS and pick up the software. Dammit, lol. I guess I'm gonna have to buy another wideband. Had the innovate LM1 before, might try something different this time.
Old Jan 3, 2006 | 11:54 AM
Eazzy's Avatar
Eazzy
Im running the Vortech w/ split Sec box-3.12,Headers,5/16 spacer,cat drop,Borla,JWT Flywheel. Just pushin 380 now with 6PSI Boost ---Have since increased boost a little. Soft ware is available from Splitsec --www.splitsec.com -----949-863-1359.-----Check out Super Chargers for Less out of Louisiana---Talk to Mike ---Thats all they do ---No Turbos
Old Jan 3, 2006 | 11:56 AM
booger's Avatar
booger
You may want to look into the Zietronix . Its a wideband , boost , and EGT gauge all in one . It also datalogs . Small 4"+2" digital read out [ around there ] . They use very good sensors , A/F reads into the 9's - unlike alot of the other widebands that dont read under 11to1 A/F . The whole package runs about the same as an expensive wideband .
Old Jan 3, 2006 | 11:58 AM
chimmike's Avatar
chimmike
yeah, I've heard good things about zeitronix. The Innovate was a decent setup but seemed to go thru the wideband sensor too frequently.
very encouraging information here, thanks guys!
Old Jan 3, 2006 | 12:05 PM
booger's Avatar
booger
www.superchargersforless.com
www.superchargersonline.com This is another good place
Old Jan 3, 2006 | 01:01 PM
Lil's Avatar
Lil
I'm running the Vortech SC, with Crawford Cats, Headers, Plenum, Borla TD and the SC put down 417. Everything is running great!
Old Jan 3, 2006 | 01:10 PM
acg's Avatar
acg
I am running the Vortech with the 3.12 pulley and exhaust, Y pipe, cats, headers and cams and put down 415rwhp and I am still on stock internals and using the SS box.
