rich...more boost?
Old Jan 3, 2006 | 06:03 PM
Midnyte's Avatar
Midnyte
Question rich...more boost?
Just curious. With the mods below I'm hitting 9psi easy. My wideband o2 sensor shows me running at 10.6 - 11 afr. I tried to see what my afr would be if I raised my boost to 10psi. It showed high 10's to mid 11's. If I were having a drop in fuel pressure, wouldnt my afr been more lean at the higher boost? Does that mean that I have a waaaay rich tune that I can boost higher? I am eventually going to get the return fuel kit, but i'm looking to see what I can squeeze out of her before I drop that extra grand. Any thoughts?
-Blaise
Old Jan 3, 2006 | 09:23 PM
MIAPLAYA's Avatar
MIAPLAYA
You techincally could run a little more boost to compensate but I would ber VERY careful with that...
Old Jan 3, 2006 | 10:56 PM
phunk's Avatar
phunk
CJ Motorsports
its not worth it... you gotta leave room for your margin of inconsistency. on piggybacks you can see up to an entire point difference in A/F depending on temperature variance... not to mention what if you turned up the boost a little and then it spiked a little more.
not worth it IMHO, but its your ride!
Old Jan 4, 2006 | 03:49 AM
Midnyte's Avatar
Midnyte
but according to the current readings, I should be okay between 9-10psi...correct?
Old Jan 4, 2006 | 04:21 AM
MoodDude's Avatar
MoodDude
9 psi is safe with an AFR less than 12. Most turbo kits go a little overboard (to cool down the temperature) and put more fuel in. Most of the designers place the fuel map between 10.5-11.5. I would leave it alone - you are running safe. If you go higher than 9 psi, talk to people whe have done it SEVERAL times before you do.
Old Jan 4, 2006 | 07:53 AM
MIAPLAYA's Avatar
MIAPLAYA
I agree with everything said..and yes if your AFR is in the 11s at 9 PSI you are fine.
bcoffee20
Nov 19, 2015 06:39 PM
kyin
Oct 15, 2015 05:54 AM
codek
Sep 28, 2015 03:03 AM
