Turbo Blanket Fitment?
Old Jan 13, 2006 | 08:54 PM
JETPILOT's Avatar
JETPILOT
Default Turbo Blanket Fitment?
Will either of these turbo blankets fit the TN turbo? I'm not familiar with these turbo's listed to cross referencer size.
http://www.mvpmotorsports.com/Templa...CatalogID=6289
Respect
JET
Old Jan 14, 2006 | 10:52 AM
plumpzz's Avatar
plumpzz
White i believe. Check on the matrix sheet TN has on their website
Old Jan 14, 2006 | 02:12 PM
35ounces's Avatar
35ounces
03 CS Track 6MT
you really think thats any better than the heat shield that TN provides?
My shop was going to put a blanket on the turbo until they saw the heat shield that came with the kit and decided just to use that.
Old Jan 14, 2006 | 02:42 PM
JETPILOT's Avatar
JETPILOT
I have one on my Grand National and it is amazing. Much better than the shield. The shield doesn't cover the whole turbo, and still allows it to radiate heat into the engine compartment. The blanket completely insulates the turbo. Much better.
Respect
JET
Old Jan 15, 2006 | 03:03 PM
ZPHILE's Avatar
ZPHILE
Seems others don't have issues with a turbo blanket, I guess. But just wondering, is it possible that the blanket can make the turbo itself hotter and thus causing issues???
Old Jan 15, 2006 | 03:13 PM
35ounces's Avatar
35ounces
03 CS Track 6MT
Respect
JET
interesting. Might have to look into one. That corner of the car gets pretty hot in the summer. Post up the info and pics when you do it.
Old Jan 15, 2006 | 03:15 PM
MIAPLAYA's Avatar
MIAPLAYA
You might also consider sending the turbine housing out for coating. Swain Tech or Jethot...it would drop the temps from it DRASTICALLY. If of course you have alternated transportation..
Old Jan 15, 2006 | 04:11 PM
35ounces's Avatar
35ounces
03 CS Track 6MT
Yeah I would like to get the housing coated from swain (and piping too) but the shop says its a fair amount of work to remove/reinstall all that. I might entertain it if the WG fix comes out and that requires piping replacement.
Does that make sense?
Old Jan 15, 2006 | 04:27 PM
MIAPLAYA's Avatar
MIAPLAYA
Yeah it does...I may be removing everything on my car in the next couple weeks and just biting the bullet and sending everything out to Swain Tech...
Old Jan 15, 2006 | 05:47 PM
taurran's Avatar
taurran
I've been thinking of getting one of these for a long time. I don't really feel like dismantling my kit and the turbine housing just to coat the thing. I haven't found any turbo blankets that will definitely work with the 60-1 though.
Old Jan 15, 2006 | 05:49 PM
MIAPLAYA's Avatar
MIAPLAYA
Any blanket that will fit a T3 or T4 turbine should fit that turbine side. The turbine included on this 60-1 is an oversized version of a T3 (Stage V being the designation) just barely smaller then a T4 turbine section... You can get the exact outer measurements of it from www.turboneticsinc.com
Old Jan 15, 2006 | 05:54 PM
taurran's Avatar
taurran
Actually, I should have stated that I was more interested as to if it would fit overall. Its pretty close proximity in there with the intake pipe, etc. The blanket Jet linked looks sweet though, but I'm not sure if it's worth the $150 they're charging for it. Anyone care to be the guinea pig?
Old Jan 15, 2006 | 05:55 PM
MIAPLAYA's Avatar
MIAPLAYA
I believe the one he linked is the Boost Logic one and yes it should fit fine. It is pretty expensive...
Old Jan 20, 2006 | 09:45 AM
35ounces's Avatar
35ounces
03 CS Track 6MT
Do you guys know much about the Swain Tech coating? Have you seen it first hand?
I was talking tot he shop today about having the housing and pipes sent out to coat. One of the guys highly recommended Swain Tech but another said the material looked bad and can flake off?
Old Jan 20, 2006 | 12:15 PM
chimmike's Avatar
chimmike
i've never seen swain or any thermal type coat flake off. They don't keep that brand new look once they're really heated like crazy, but swain and jet hot coats among others are excellent....but still I say a blanket or wrap is the best bet for absolute temp reduction.
swain coating will help spoolup more than anything simply by keeping the thermal energy in the exhaust track instead of leeching off to the turbine housing or downpipe, etc.
Old Jan 20, 2006 | 05:03 PM
DBZ33's Avatar
DBZ33
Can someone buy this and try it. It would be great if it works on our TN kit.
sales@czp
Sep 23, 2019 03:30 PM
