Converting from supercharger to TT
Old Jan 15, 2006 | 07:52 PM
Eagle1's Avatar
Eagle1
Default Converting from supercharger to TT
http://forums.freshalloy.com/ubbthre...b=5&o=&fpart=1
Going to a Jim Wolf prototype with Garrett ball bearing 530 twin turbos (modified), and a long array of other changes. Built motor with CP pistons at 8.5 to 1 CR and Pauter rods, Jim Wolf S2 cams, and a target of 500+rwhp and 500+ lbft of torque. There are now two chapters on the build, and in awhile a third will start up. Very big tires and wheels, some unique features (amsoil pre-oiler and bypass filter, Motordyne iso thermal spacer,and a fluidamper harmonic balancer for the crankshaft, to name three). Ultimately hope to get some review of the torn down old motor to check on the wear during the use of the Procharger, and also to check on the internals of the supercharger, in particular the impeller blades and the bearings, over 23,000 miles of use.
Old Jan 15, 2006 | 08:51 PM
WA2GOOD's Avatar
WA2GOOD
Sounds GREAT........and who is performing all of this awesome work?? (shameless plug) Hehehe........
Old Jan 15, 2006 | 09:14 PM
Zilvia's Avatar
Zilvia
no other than VRT of course
Old Jan 16, 2006 | 04:45 AM
booger's Avatar
booger
MAy I ask where you got the fluiddamper at and how much ? Good Luck
Old Jan 16, 2006 | 04:56 AM
booger's Avatar
booger
Eagle..I seen in the thread over at Alloy . You said you are going to run 2 maps for diff. gas . JWT uses the SS box , are you going with a diff. piggyback to be able to switch from map to map . Or are you just going to load up a diff. map to the SS box when needed ?
Old Jan 16, 2006 | 06:19 AM
Eagle1's Avatar
Eagle1
Summit Racing. Here is the link. Approximately $350.00
http://store.summitracing.com/
Old Jan 16, 2006 | 07:56 AM
mraturbo's Avatar
mraturbo
Ultimately, a simple lap-top connection can change the maps with 15-20 seconds.
Old Jan 16, 2006 | 11:34 AM
plumpzz's Avatar
plumpzz
Very nice mike, yes i have recieved your phonecall and i'll call you when i can reserve a nice 30 minutes for you
Old Jan 16, 2006 | 01:52 PM
booger's Avatar
booger
Yes I know...As the Vortech runs the SS box . Just was asking if he plained to use the SS box or go a different piggyback
Old Jan 16, 2006 | 02:01 PM
jdx911's Avatar
jdx911
http://www.atiperformanceproducts.co.../damnissan.htm
Old Jan 16, 2006 | 02:21 PM
Eagle1's Avatar
Eagle1
The ati is a different mechanical approach to the problem of reducing torsional vibration than the fluidamper:
http://www.fluidampr.com/images/howitworks_new.jpg
They both work.
Old Jan 16, 2006 | 02:45 PM
booger's Avatar
booger
THX guys..I'll look at both
Old Feb 14, 2006 | 10:28 PM
John at J&S's Avatar
John at J&S
I read that Clarke at JWT had designed their own timing and fuel controller.
Old Feb 15, 2006 | 10:23 AM
WA2GOOD's Avatar
WA2GOOD
Yes, I believe you heard correct.
Old Feb 15, 2006 | 11:17 AM
booger's Avatar
booger
Doesnt several of the JWT cars have the SplitSecond box using the R4 program ?
Old Feb 22, 2006 | 01:47 PM
Eagle1's Avatar
Eagle1
The "diagnostic" day at Streets of Willow went as well as one could hope. The car went straight from the shop floor to the track, so we had not had time to tune the suspension. With the tightened front end and significant tire stagger in the set up, the car gripped like heck, but also understeered or "pushed" at the extreme, which as you know forces you to slow down at the limits. We also had a little bit of a high pressure oil leak, and some issues with the EDFC cutting out on the Tein flex coils, we think on the right front.
Nevertheless, the car with Scott driving it ran a 1:25.667 lap time and was the fastest car tested that day. So a good start that Friday. Then we brought it down to LA, gave it a wash and some TLC, entered it in the DUB Magazine car show at the LA Convention Center, where it took third prize in the 2 door coupe category. We are going to send it back to VRT for some tweaking to get the suspension dialed in and check a gasket or two, and then we should be ready for some serious track time.
Old Feb 22, 2006 | 02:49 PM
Zilvia's Avatar
Zilvia
post some pics i wanna se those 315s man....freakin huge
Old Feb 22, 2006 | 04:57 PM
WA2GOOD's Avatar
WA2GOOD
Here is some pics.......
The left one is a 315/30/18 (rear) and on the right is a 275/35/18 (front)
Old Feb 23, 2006 | 05:48 AM
Zilvia's Avatar
Zilvia
man, Ill be sure to hit you guys up when i need to get some mad traction
i went flippping tho his 4ch post up on FA..........crazy
Old Feb 24, 2006 | 05:52 AM
Eagle1's Avatar
Eagle1
Zilvia:
The Nitto NT-01 and Toyo RA-1 have treadwear ratings of 100, yet are still DOT-R approved, so you can run them on the street if you want. They will not last a super long time with that soft a rating, but if you stay out of the wet you will enjoy them! However, if you really want some traction, you can go to some other tires that are really "grippers", like the Hoosiers, that deliver a very soft 40 treadwear rating and are very amazing....but not for the street. I think that there is a Yokohama or Kumho offering that goes as soft as 30! But again, not for the street.
There is a pretty good Chapter 5 now on the build, with some pics of the little car hauler trailer too. We will try to run the car at Time Attack in a couple of weeks for a better suspension tune. that will probably be the start of a new Ch 6, which will be directed to the experiences on the tracks with the finished, or close to finished, car.
Cheers.
Ed
350Z_Al
Oct 29, 2020 07:44 PM
sales@czp
Sep 23, 2019 03:30 PM
seagrasser
Oct 11, 2015 03:27 PM
Fixxxercask
Interior
Oct 6, 2015 10:17 AM
Calinismo350z
Sep 14, 2015 04:04 PM
