Does anyone have experience with UTEC and exactly what setup are you using????
Old Jan 16, 2006 | 03:58 PM
craigo'sznprgrs's Avatar
craigo'sznprgrs
Exclamation Does anyone have experience with UTEC and exactly what setup are you using????
Please tell me if you run only the UTEC, or if you have the TUNER ADDITION, or the TUNER PRO ? What gains are you getting or better yet, do you have to have anything in combination with the UTEC, to tune ? Sharif was very helpful with this situation, and I was wandering if anyone else has or recommends the UTEC. I have bought the UTEC, and now I am curious to see if I need anything else to help dial/tune my Z in, I am down to my LAST !!!
Craig
Old Jan 16, 2006 | 04:40 PM
KTaylor's Avatar
KTaylor
Craig
i have the utec with the tuner piece not tuner pro. you also want to get the map sensor and the map switch thing to change your map. i cant think of anything else but just talk to sharif he is the best source for info on this.
Old Jan 16, 2006 | 05:04 PM
BobbyRitz's Avatar
BobbyRitz
Craig
I have UTEC installed on my NA Zr. I definitely recommend UTEC for FI applications, particularly the TN kit as it only comes with an ECU reflash.
There are many more qualified folks on this forum, but you can only benefit from having UTEC added to your TN setup.
I picked up 15whp w/ UTEC tuning and approx. 20 ft/lbs of torque on my NA application.
The results will be MUCH better on an FI application.
EDIT: I have the Tuner Reg Pro with Map Switch
Old Jan 16, 2006 | 05:22 PM
Julian@MRC's Avatar
Julian@MRC
The UTEC needs to be tuned for your particular application and mods.the base maps for the Z are a starting point only and will not really make any power.
We have several comming in late this week that are unspoken for if you need one..
WWW.RACEMRC.COM
For your 350z/G35 performance needs.
Authorized Turbo XS UTEC distributors
Authorized Dyno Dynamics load based tunning facility comming 3/06!!
Authorized Greddy Dealer/Installer
Authorized GTSPEC dealer
Authorized Unlimited Tuning Revolution dealer
Authorized Speed Force Racing Dealer
Email: Sales@racemrc.com
AIM: salesmrc
Phone: 732-251-8200
Mobile: 732-558-4560
MRC MOTORSPORTS
116 Main St.
Spotswood NJ 08884
Old Jan 16, 2006 | 05:46 PM
D350Z10's Avatar
D350Z10
I am using the
UTEC
Tunner pro with headphones to hear engine bay and detect knock/ and A/F
Aem A/F GAUGE ONLY to work with tuner pro
Map Switch
Map sensor
Am currently being tuned for all 5 maps!! and should be done this week
From what I have heard from my shop everything is GREAT!!!
Old Jan 16, 2006 | 06:15 PM
35ounces's Avatar
35ounces
03 CS Track 6MT
DB350z10:
you have the tuner pro sending the a/f signal to the aem wideband gauge? So you are not using the aem a/f sensor/sender? If so, thats cool.
Old Jan 16, 2006 | 06:16 PM
craigo'sznprgrs
I can't wait to get mine tuned, what is a good price for the tuner reg piece and the tuner pro? I bought the UTEC, but now need to know how much is a good price on the rest?
Old Jan 16, 2006 | 06:17 PM
D350Z10's Avatar
D350Z10
yes... I just got a hold of the gauge only and the tunner already has the bosch sensor so it is good to go and you just plug and play!
Old Jan 16, 2006 | 06:20 PM
Julian@MRC's Avatar
Julian@MRC
PM sent..
35ounces's Avatar
35ounces
03 CS Track 6MT
hmmn, I wonder if that will work with MY aem...its the older one that only goes down to 11. I bet it will not work or at least not plug and play like yours. I think they may have changed the connector.
That is cool though.
Old Jan 16, 2006 | 06:22 PM
Julian@MRC's Avatar
Julian@MRC
If the sensor is a bosch or VW one it SHOULD work with the tuner and tuner pro..
Old Jan 16, 2006 | 06:24 PM
BobbyRitz's Avatar
BobbyRitz
Originally Posted by D350Z10
I am using the
UTEC
Map Switch
Map sensor
That is good to know...I'm prolly going FI in the coming months...
I have the map toggle switch too...what maps are you having tuned?
93/100/racing gas? Different boost maps?
Old Jan 16, 2006 | 06:28 PM
35ounces's Avatar
35ounces
03 CS Track 6MT
not sure what kind of sensor they included back then, probably bosch but AEM came out with a newer version of their wideband gauge since I got mine. The new gauge has a connector among other changes. So I think with the new gauge you can connect from the tuner/tuner pro unit directly to the gauge as DB350z10 did. Mine might have to be spliced in. Not sure.
DB350z10: where did they mount the tuner unit? Also, did the map switch fit next to the VDC button? I'm waiting for TurboXS to release the right map selector switch for the Z.
D350Z10's Avatar
D350Z10
I use sunco 94 octane and that is on 3 of my maps..... stock 8psi, 8.5 psi and 9.5psi and then 100 octane at 9.5psi and then 110 octane at 8.5 psi!
That is what we have planned... hopefully done at the end of this week.. SO MUCH damn data loging lol... its alot of work so when tuners give you a scary price its WORTH it!
Old Jan 16, 2006 | 06:31 PM
D350Z10's Avatar
D350Z10
Thats a great Idea... I dont know where they have mounted the stuff yet but Will ask tomorrow, I am thinking if possible in the center council, so it would be easier to listen with the headphones.
Old Jan 16, 2006 | 06:35 PM
Julian@MRC's Avatar
Julian@MRC
I mounted mine on my passenger side of the shifter with velcro..
Old Jan 16, 2006 | 06:37 PM
craigo'sznprgrs
dz350z10, pm me with some pics of where you mounted it, so I can get some ideas, thanks
Craig
Old Jan 16, 2006 | 06:43 PM
BobbyRitz's Avatar
BobbyRitz
My map switch was installed in the open bay next to the seat heater switch. What do you mean by "right" map selector swich?
Old Jan 16, 2006 | 06:46 PM
D350Z10's Avatar
D350Z10
Craig
No prob I am going to get it mounted in the center council cubby... where cup holders... I am justing taking those out and place it in there. I will stop by there tomorrow to see if its mounted!
Old Jan 17, 2006 | 06:08 AM
mickey's Avatar
mickey
Hi D350Z10, Is Dan(ex-godspeed) from Tuning Factory doing the UTEC mapping and tuning?
Cheers,
Mike
