Random Technology Cats Question
Old Jan 18, 2006 | 11:05 AM
Hollywoodfraser's Avatar
Hollywoodfraser
Default Random Technology Cats Question
Anyone running Random Technology High Flow Cats with F/I set up? Any comments?
Old Jan 18, 2006 | 11:06 AM
VegasZ35TH's Avatar
VegasZ35TH
I am running RT High Flow Cats but with an N/A setup.
Old Jan 18, 2006 | 01:41 PM
Zivman's Avatar
Zivman
If you are talking a TT setup I wouldn't run any cats in fear of them melting/collapsing. Random Tech cats had a bad rep for collapsing under N/A conditions. Not worth the risk IMO.
Old Jan 18, 2006 | 02:23 PM
JeffesonM's Avatar
JeffesonM
+1... mine collapsed after just a few months of use, and that was NA.
Old Jan 18, 2006 | 05:38 PM
booger's Avatar
booger
Mine collapsed also 3000 miles with a SC . Thye do flow better than any other HFC
Old Jan 18, 2006 | 05:46 PM
TheLastSpartan's Avatar
TheLastSpartan
what cats are good for turbo and NA...(dont tell me TPs)
anything good besides crawfords?
Old Jan 18, 2006 | 07:26 PM
SungNamZ's Avatar
SungNamZ
I am running R/T Cats with my Vortech SC. Roughly 16,000 miles with no problems.
Old Jan 18, 2006 | 07:29 PM
DomZ's Avatar
DomZ
I have gutted RT High Flows, if they collapse...first of all it will take a long time. Second of all, once they collapse just gut them and you have resonated test pipes that pass visual inspection for cats! They flow great for me...combined with plenum spacer/intake, the combo lowered my ET almost .2 (I haven't actually been out on as good a tire as I did before so my times may even improve more!)
ZU L8R's Avatar
ZU L8R
Viper Sellout
Mine lasted 6 days, NA. Gutted them. Don't buy them
Old Jan 18, 2006 | 07:44 PM
Ztrackman's Avatar
Ztrackman
Got over 25,000 miles with RT cats NA- no problems.
Old Jan 18, 2006 | 08:00 PM
StarcraftBW's Avatar
StarcraftBW
10k on my R/T with NA..............not a single problem ....still passed emission wohooooooooooo
Old Jan 18, 2006 | 09:14 PM
Aloharacing's Avatar
Aloharacing
i have them with the greddy kit. No issues after 9K miles although I've been thinking of getting test pipes (or the DP's that Sharif was talking about that will go from the compressor flange to the exhaust).
Old Jan 18, 2006 | 09:25 PM
Nexx's Avatar
Nexx
so it looks like 50/50 on RT failing so far, i know its not very scientific but, im not gonna take a chance spending a good chunk of cash on these.
Old Jan 19, 2006 | 05:22 AM
Eagle1's Avatar
Eagle1
I had a set and they collapsed on my FI car as well.
Old Jan 19, 2006 | 05:37 AM
Hollywoodfraser
I also bought a set through Stillen. They rattled the same day I put them on the car. I contacted Stillen and they told me to contact Rtech directly! Way to stand by your supplier Stillen!!!
Anyway, after some persuasion, Rtech finally agreed to replace them. What is the use though. It will only be a matter of time before they collapse.
My advice - stay far away from Rtech. There is a better way to spend $700. Stillen's name has been tarnished in my opinion!
Old Jan 19, 2006 | 02:25 PM
tonio's Avatar
tonio
Bad customer service as well, they are located in Loganville and I physically took my collapsed cats up there and I damn near had to twist their arm to get them replaced.. they argued that their products were perfectly fine and something was wrong with my car.
Mine collapsed twice and I ended up gutting them.. very expensive test pipes.
Old Jan 21, 2006 | 07:53 AM
Gary King's Avatar
Gary King
The collapsing problems were only occurring with their metallic versions which flow great when they are not collapsed. Random claims the collapse is caused by cars which are not tuned properly and allow un-combusted fuel to pass into them, which ignites in the cat causing the collapse.
They have had a ceramic version for a while now which does not have the issues of the metallic’s. I have had these on my Z for about a year and they have been great.
Go with the ceramic’s and they will be fine. They fit perfect and Random does warranty their products.
Old Jan 27, 2006 | 11:16 AM
OvaYahead's Avatar
OvaYahead
Is there a visual way to tell if the RT cat is metal or ceramic?
Old Jan 27, 2006 | 03:10 PM
StarcraftBW
+1
http://i18.photobucket.com/albums/b1...k/DSC00551.jpg
http://i18.photobucket.com/albums/b1...k/DSC00548.jpg
http://i18.photobucket.com/albums/b1...k/DSC00547.jpg
http://i18.photobucket.com/albums/b1...k/DSC00549.jpg
after 14,000 miles with N/A......if you dont' experience, please don't give the false information.......
Old Jan 27, 2006 | 04:38 PM
Gary King's Avatar
Gary King
I have never compared them side by side but they do look different on the inside. You have to look at the honey comb material, the metalic is a grayish color where the ceramics kind of a light brown. But that is new, put some miles and some carbon on them and you may have to tell just by the thickness of the material, the metalics I believe are thinner more dense. I have not looked at a new set of these in a while so I could be off but that should give you an idea. It's two totally different materials inside the things so I think most mechanics should be able to tell what it is just by feeling it.
