Question? Maintance TT Z
Originally Posted by barthelb
Oil/Filter-Change every 2500-3000
SparkPlugs-same ones with APS kit
Warm-up I let it idle until it gets to 850rpms about 3mins every single morning
Shut down- I baby the car the last 1-2 min. before shutdown and give it about 3 lil revs, then 10seconds idle before shutting down.
Gas-Always mix at least 6gal 100oct
Miles on kit-23000
Years on kit- 1yr installed Jan.05
Miles on kit-23000
Originally Posted by Chebosto
check engine oil regularly. the harder you drive, the more blow-back will occur, especially with this VQ, which seems is notorious for blow back. if u have a catchcan, then check often/clean.
I used only Mobil 1 Full Synthetic 10w-30, changed every 3500 mi with a nissan shorty oil filter.
i run one step colder plug NGK plats. i havent changed them yet since my turbo install (about... 15k ago) but i do check them to see how they're holding up, about every 6k or so.
thanks
nexstage
Oil - Mobile One full synethitic 10w-30 - every 3000 miles
Filter - really don't worry about it since it is changed so often
Check - I check under the hood every other gas fill up
Plugs - Changed when APS TT installed- Need to check on them since it has been a year
Air filter - Cotton type filter - clean every 12,000 miles unless I drive on dirt roads.
Start up - I let my car warm up until my exhaust reads 400 F and my oil reads 25 C
Shut down - easy on the last 5 min of driving, turbo timer set at 60 seconds
Transmission and diff - plan on changing oil on these at 30k
Tire rotation - can't do it on mine
Alignment - every year and/or tire change
Tire Balance - every year and/or tire change
Mileage tracking - every fill up
Fuel filter - probably at 2years.
Can't think of any thing else
Originally Posted by nexstage350
thanks!
btw i just got a new plenum polished, what is the torque specs on putting it back on?
30 in-lbs than 60 in-lbs than 90 in-lbs than the 100 in-lbs.
Just remember this is in-lbs NOT ft-lbs!!!!
Originally Posted by MoodDude
plenum should be 100 in-lbs of torque on each bolt. There is a specific pattern for the order which they should be tightened. You should also do it in stages:
thanks for your info! what about changing out your plugs? what is the spec on it?
thanks! where can u pick that mobil M1-105 oil filter?
on the turbo timer, will it work with your alarm? i have an aftermarket alarm, but dunno if it will work with it?
thanks
nexstage
thanks
nexstage
There alarms now that come with built in turbo timers.
hey when u change ur plugs or check them, what is the torque specs on installking them? i don't have a torque wrench so just trying to figure out what is the correct amount of torque i should apple.
thanks
nexstage
thanks
nexstage
spark plugs, i believe are hand tighten only. don't over do it... i think they'er probably like 15-21fl/lbs only.. aka hand tighten only.
Originally Posted by Gman2004
My turbo timer works with my aftermarket alarm (Clifford G5) but I lost the auto arm feature because the driver door does not open and shut after the car turns off since I have already left the car. I had to go back to the alarm shop and they installed a relay to allow me to arm the alarm while the car is still running. Without that relay, I had to wait in my car until the turbo timer shut off so I could arm the clifford. Kinda defeated the turbo timer purpose.
thanks!
gotcha! how is ur gas mileage with with the oil u are running with ur turbo?
thanks
u know what alarm works with it?
thanks!
thanks!
