APS TD 3'' exhaust pic
Old Jan 20, 2006 | 01:54 PM
G3po's Avatar
G3po
Originally Posted by Sharif@Forged
The airbag sensor ares are g-force driven...how would a sound wave simulate several g's worth of deceleration or impact?
Navy, my car pretty much sounded 3 or 4 twin prop Cessna's at take-off.
Odd but it definately happened, G-sensors have a natural resonant frequency, hit the right resonance at high enough amplitude and what the sensor sees becomes "constructive".
It's analogous to a singer breaking glass. The glass can be broken either by dropping it on the floor (impact) or by constructive (additive natural resonance).
Old Jan 20, 2006 | 01:55 PM
Navygolf13's Avatar
Navygolf13
How long you think I could run that before I got a ticket out here, huh? lol
Old Jan 20, 2006 | 02:35 PM
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
I'm sorry...but I'm going to have to disagree here. The amplitude that would be required to simutlate an impact like that would be massive. Far beyond what a normal internal combustion motor can produce.
I know of tons of cars that are much louder than a twin turbo Z running off the dp's, and none of them have ever had an airbag go off due to the sound from the exhaust. There had to be another factor in that situation.
It's analogous to a singer breaking glass. The glass can be broken either by dropping it on the floor (High G deceleration) or by constructive (additive) sound resonance.
A glass dropped on the floor doesn't break due to deceleration. It breaks from the force of impact on a very small surface area on the glass. Futhermore, do you know what kind of dB levels are required to break glass???
Old Jan 20, 2006 | 02:49 PM
G3po's Avatar
G3po
I'm not going to argue , it did in fact occur , on the dyno, open TPs in a very "closed" space. The G-sensors are not perfect , they have finite mechanical structures (modern cars use MEMS ) which can respond to constructive resonance.
The rough glass analogy is simply put to show how an impact or constructive resonance can yield similar results. A microwave oven does not impart massive heat amplitude to the food being cooked , it constructively resonates the water molecules over an extended interval of time.
Old Jan 20, 2006 | 03:04 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Based on my 15 years experience, living and driving in Los Angeles and Orange County...I am going to say.....47 seconds.
Old Jan 20, 2006 | 03:06 PM
barthelb's Avatar
barthelb
Master
If you don't think it can or did happen, stand next to the airbag on the seat when you dyno your car with no testpipes on and have some of your friends tape it cuz we'd love to see what happens. The force of the airbag would probably knock you down or out, maybe both. Luckily the guy running the car barely got knicked on the arm and still would up with a lil bruise.
Old Jan 20, 2006 | 03:15 PM
G3po's Avatar
G3po
Maybe this could be a new episode for the Myth Busters .
Old Jan 20, 2006 | 03:21 PM
G3po's Avatar
G3po
Default resonance
I'm sorry...but I'm going to have to disagree here. The ........ Futhermore, do you know what kind of dB levels are required to break glass???
http://www.physics.ucla.edu/demoweb/...ith_sound.html
Well I do now , about 140dB in close proximity
Navygolf13's Avatar
Navygolf13
Who are these guys talking about resonate frequency and constrictively resonating water molecules???
But Sharif, I think your 47 second guess is probably about right!!
Old Jan 20, 2006 | 03:24 PM
G3po's Avatar
G3po
[QUOTE=Navygolf13]Who are these guys talking about resonate frequency and constrictively resonating water molecules???
QUOTE]
A bored geek I guess
Old Jan 20, 2006 | 03:56 PM
plumpzz's Avatar
plumpzz
It takes less than 1 watt of power to break glass w/ sound. Glass is too rigid to bend and allow transfer of sound... a G force sensor works in a different way, and it measures deceleration.. even if it could happen with the sound, the direction of the waves would never be perfectly horizontal to actually switch off the airbag.
However, theres is a possibility... airbags are set off w/ hydrogen azide, a highly combustible compound... the sound waves can very well cause it to combust and cause the airbag to deploy w/o the sensor actually tripping
Old Jan 20, 2006 | 04:25 PM
350zDCalb's Avatar
350zDCalb
builtZmotors
I have a story of a reputable shop doing open test pipe tests on the dyno during tuning and ka-bang the passenger side air bag deployed. Cos tto replace ~ $2k. Sooo open pipes waaaaay too loud and can be costly if not dangerous
no way... just a "story"
it wasn't the sound that triggered the airbag
Old Jan 20, 2006 | 04:37 PM
failsafe306's Avatar
failsafe306
Wow, this all has so much to do with the APS exhaust! Subscibing!
Old Jan 20, 2006 | 06:48 PM
CESAROTORRES's Avatar
CESAROTORRES
Question Louder?
I will assume that the new exhaust will be louder than the APS 2.5 exhaust.
Cesar
Old Jan 20, 2006 | 07:11 PM
baptist's Avatar
baptist
Off topic south central!!! Start another thread!!!!!!!!!
350Z_Al
Oct 29, 2020 07:44 PM
sales@czp
Sep 23, 2019 03:30 PM
Li1ag
Sep 28, 2015 02:07 PM
