How many power could support the cheapest forged internals?
Just for us to know,
Wiseco 8.8:1 pistons cost near half of jE and arias (around 675$)
Eagle rods cost half of pauters and carrillo or crower rods (around 550$)
Which type of F/I engine could we make with those? (power; torque; reliability)
Cheap is good or bad in this case?
Dont take my word for it, but i think i heard of someone using eagle rods, that went **** up at around 550 rwhp. To be sure, i wouldn't go over 450-475 with cheap internals. Best invest in something better and have the peace of mind. If your gonna take the engine appart and do internals, you might aswell do it right.
power goal would be 450hp-475hp (on 93 octane ,98 in france) but with peace in mind instead versus stock internals(like someone are doing there
i think 500hp+ not good for street use , roads in europe aren't straight as yours
When you tabulate the entire cost of building your motor, the difference between low end parts and high ends parts is minimal. Eagle rods can certainly hold 500whp, and probably much more. Pauter is the ultimate strength rod. For pistons, I have heard mixed reviews on Wiseco, so we dont carry them. FYI: Arias pistons are $760 on our website, with rings, wrist pins, and locks. So I wouldnt try to cut corners for $100.
But I would see no problem in going with Eagle rods and Arias pistons. Pauter is more applicable for those where funding is abundant, and/or, the 550whp+ club.
Link to Arias pistons: http://www.forgedinternals.com/store...cat=248&page=1
Link to Eagle Rods: http://www.forgedinternals.com/store/home.php?cat=249
Always in stock!
Always in stock!
What is 0.20 overbore for arias ?
We have to cut 0.2" in the liners to drop them in? doing this operation could be very expensive in france you know.
sorry for any comprehension mistake my english is poor..
I am running eagle rods in my car with arias 8.8:1 pistions. from the research I did, they should hold to near 600 whp. The 300Z boys run them pretty high.
my car is running a stock APS kit with upgraded actuators. no cams. I think I have maxed out the basic kit, no counting the actuators. the lower compression will hurt your power up top without more fuel than the stock APS supplied injectors can provide.
my car's specs
my car's specs
Originally Posted by plumpzz
Whats the poitn of using lower Comp pistons if you'll need more boost to begin with for the same power??
Originally Posted by overZealous1
the lower comp pistons just allow you to run alot more boost past the point where the stock 10.3-1 would detonate. it is a cylinder pressure/heat trade off. you will lose a little bottom end and throttle responce, but you will make up for it hugely with the amount of boost you can run on the top end.
I havent see much meaningful differences between 8.5:1 pistons and 10.3:1 in terms of trq curves. Theoretically, 10.0:1 CR dropped to 9.0:1 results in a 3% power/trq loss, which is something you will not even feel.
Oh, I disagree. There are plenty of reports from people on this board that can tell a 3%, or even 1% or 2% difference in power just from z-tubes, k&n filters, CAIs, exhausts, y-pipes, etc.
But seriously, oftentimes, people will feel power gains that arent even there, due to the increased noise that a CAI will generate.
