Turbonetics owners come in....
Old Jan 24, 2006 | 01:59 PM
MIAPLAYA's Avatar
MIAPLAYA
Originally Posted by Alberto
You can but you would have to modify it to fit the 1 downpipe with a reverse y-pipe. I personally wouldnt buy a new exhuast and hack it up though....and anything too "good" ie free flowing and you'll be on the overboost list.
For now...pipes are coming out of production soon to make this an non-issue..
Old Jan 25, 2006 | 01:37 AM
solidsnake's Avatar
solidsnake
All I have is the boost guage. I drove it home from work tonight. Temp around the same. 55ish. I hauled *** from second through 5th shifitng at about 6k. Car ran just fine. It was right about 5lbs of boost. Im going to call turbonetics tomorrow and see what they recommend. Only thing I dont get is how miaplaya can throw on an exhaust as well as a spacer and not have any problems. Did you have it reflashed after mods? And before you guys bash me Im working on getting an A/f guage. Any recommendations? Not too expensive.
Old Jan 25, 2006 | 07:40 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Why only 5lbs of boost? Sounds like you have a leak...
Old Jan 25, 2006 | 09:14 AM
MIAPLAYA's Avatar
MIAPLAYA
If you are going into limp mode at only 5 PSI of boost you definitely have a boost leak somewhere. Do you have a spacer or plenum on there? If so what kind?
Old Jan 25, 2006 | 11:38 AM
solidsnake's Avatar
solidsnake
No spacer or plenum. Ill talk to my mechanic and tell him wassup. Ill keep you guys posted.
Old Jan 25, 2006 | 02:31 PM
Peking's Avatar
Peking
Check the location of the vacum line to the BOV... Make sure it is in the top port... Shop I used put it in the bottom port and I was at 5 psi consistantly. Then swapped it and bam 8 psi.
Old Jan 25, 2006 | 02:48 PM
MIAPLAYA's Avatar
MIAPLAYA
Good call...everyone who has overboost please check the official overboost thread..fix is DONE.
Old Jan 25, 2006 | 05:38 PM
Peking's Avatar
Peking
Just saw that thread, great info Robb and great pics
Old Jan 26, 2006 | 12:58 AM
solidsnake's Avatar
solidsnake
OK I sent a pm to the guy with tnetics. Ill check on what peking was talking about. Im not mechanic so can u possibly take pics of that and send it to my email Peking. phil_r89@yahoo.com
Old Jan 26, 2006 | 08:49 AM
MIAPLAYA's Avatar
MIAPLAYA
I have pics of mine here http://members.***.net/turbonetics350z Look at where the vacuum line goes into my BOV. Yours should be the same..
Old Jan 26, 2006 | 11:47 AM
Eazzy's Avatar
Eazzy
I did the install on Solidsnakes 04---Solid running car, Dynoed @ 377 w/ stock exhaust. Im going to chk for leaks, pull check and clean MAF, Also do a plug change---Prob a step colder Copper gapped at low 30s. Exhaust issue is interesting. More responses and recomandations are welcome.
Old Jan 26, 2006 | 11:51 AM
MIAPLAYA's Avatar
MIAPLAYA
Don't gap below .035... That should be MORE then sufficient...
Old Jan 26, 2006 | 12:44 PM
solidsnake's Avatar
solidsnake
Where is my damn 8lbs. LOL!
Old Jan 26, 2006 | 02:51 PM
Peking's Avatar
Peking
Did you check MIAPLAYA BOV pic/link? Top port is the one closest to the drivers side fender, bottom BOV port is closer to the motor.
Old Jan 27, 2006 | 01:19 AM
solidsnake's Avatar
solidsnake
yes its connected right. eazzzzzzy is going to take a look at it soon.
Old Jan 27, 2006 | 01:53 PM
Peking's Avatar
Peking
Man I was hoping that was it, good luck on finding it.
Jambo016
Sep 16, 2016 01:08 PM
kyin
Oct 15, 2015 05:54 AM
derekinthez
South East
Sep 28, 2015 06:35 PM
Tochigi_236
Sep 27, 2015 03:40 PM
