fully build cost
Old Jan 25, 2006 | 07:11 AM
faster than u's Avatar
faster than u
Default fully build cost
how much would it cost to fully buil my motor. im thinking of taking a Lone out to do it.
Old Jan 25, 2006 | 07:12 AM
faster than u
im in school and wont be able to respond till i get home so dont get mad if i dont answer
thanks
Old Jan 25, 2006 | 07:20 AM
Gman2004's Avatar
Gman2004
this gives you an idea.
http://store.yahoo.com/sgpracing-store/sgpravqmo.html
Old Jan 25, 2006 | 07:32 AM
TK2005's Avatar
TK2005
thanks
Go to www.sgpracing.com
Here's the link http://store.yahoo.com/sgpracing-store/sgpravqmo.html
They have the engine packages available. A "fully" built motor with all the goodies is roughly $15K installed. You could always spend more on heat treating and coatings. However, a fully built motor isn't necessary for most people. Most people can get away with just the short block (up to 500rwhp or so). Some will do the long block (up to 600rwhp). More than that and I would suggest just going all out and sleeving it.
TK2005's Avatar
TK2005
Originally Posted by Gman2004
You beat me to it fast guy.
Old Jan 25, 2006 | 07:51 AM
Gman2004's Avatar
Gman2004
haha!
And after you add the TT kit, guages, exhuast, test pipes, clutch, etc. You're looking at almost $25K in parts and labor.
Gman2004's Avatar
Gman2004
haha!
And after you add a TT kit, guages, exhuast, test pipes, clutch, etc. You're looking at almost $25K in parts and labor. This is what you will look like after it's done
Old Jan 25, 2006 | 07:53 AM
chimmike's Avatar
chimmike
i dunno about you guys but I'm still trying to figure out what a "lone" is.
Old Jan 25, 2006 | 07:57 AM
TheCajunStyle's Avatar
TheCajunStyle
The lone gunmen, maybe?
I'm tellin ya, the truth is out there!
Old Jan 25, 2006 | 07:58 AM
Jason333's Avatar
Jason333
hi
maybe slang for "alone"
I can't talk much, i'm a menace when it comes to gramatics and spelling..
Old Jan 25, 2006 | 08:15 AM
hurahn's Avatar
hurahn
If you're talking about a loan, I wouldn't do it.
Old Jan 25, 2006 | 08:18 AM
taurran's Avatar
taurran
No kidding. Student loans + Car loan + Engine build lone = Life sucks
Gman2004's Avatar
Gman2004
+1. The only type of loan I do for my mods and everything I buy is to pay with my credit card. Althgouh I pay the entire amount when I get my statement. Good way to earn free chit.
Old Jan 25, 2006 | 08:25 AM
Navygolf13's Avatar
Navygolf13
You guys are nuts!! There is no way that a fully built motor and all the stuff to go along with it would cost that much.
Faster than U PM me and I will help you with this. I am actually selling most of the stuff you need and you can get it all done for less than 15k. All it takes is some time and the right research!
Old Jan 25, 2006 | 08:29 AM
TK2005's Avatar
TK2005
First, you are going to have to define what you believe "fully" built means to you. You have to think a fully built motor to mean with everything. If you think you can fully build the motor for less then you should start your own racing team because some of those fools are spending in excess of $100K a year on motors. If you really want to have fun pricing built motors, try building up any M series car from BMW. Easily spend $25K on just the motor. I have priced and reasearch building the Z motor with tuners across the country and even trying to skip the tuner and go straight to the machine shops. Although you can save a little money going that route, I think SGP's markup is pretty fair. You aren't saving much getting parts from all over the place and there is much less headache doing it in one place as opposed to waiting for parts from everyone that had it a couple bucks cheaper. Also, you have someone to point the finger at if the build isn't right. Some of the convenience is built into that price and seems to be well worth it from the sheer volume of built motors coming out of SGP.
Old Jan 25, 2006 | 08:31 AM
hurahn's Avatar
hurahn
You said engine build lone!!!!
Old Jan 25, 2006 | 08:33 AM
Gman2004's Avatar
Gman2004
"Fully Built"
Ultimate Long Block: $9800 - Good to 1000+ Rwhp
Block oil passages cleaned
Block redecked
Block Bored and Honed using a Torque Plate
Crank balanced
Crank journals polished
*Darton MID Sleeves
New Main and Rod bearings w/ceramic coating
Pauter Rods
ARP Rod Bolts
CP Pistons/Arias Ultimate..your choice(8.5:1 or 11.5:1)
Ceramic coating on Piston skirts and tops
ARP Main Studs
ARP Head Studs
Heads oil passages cleaned
Heads redecked
Ported exhaust and intake runners
*Tomei Upgraded Cams
*Ferrera 1mm Over Valve Train
5 angle valve job
Valve Stem Heights set
Cold Clearance set
New Valve stem seals
New Nissan Head gaskets
New Nissan Oil Pump
New Nissan Cam seals
Complete TT kit - $7400-$8500 depending on kit and if you have to buy supplemental parts to make the kit complete.
Exhaust - $1300-$1500
Test Pipes - $200-$350
Clutch - $2200-$2700
Just right there using the low figures you have $20,900. This doesn't include gauges or installation. Install and tune would be at least $3K. Also don't forget about the incidentals.....oil, spark plugs, new radiator....this that. You see where I am going?
Lastly I am talking about brand new parts not used stuff.
Old Jan 25, 2006 | 08:54 AM
Zquicksilver's Avatar
Zquicksilver
+10! unless it's a loan for 0.01% for 5yrs... LOL
Zquicksilver
Old Jan 25, 2006 | 09:04 AM
TK2005's Avatar
TK2005
"Fully Built"
Block redecked
Crank balanced
*Darton MID Sleeves
Pauter Rods
ARP Rod Bolts
ARP Main Studs
ARP Head Studs
Heads redecked
5 angle valve job
Cold Clearance set
New Nissan Oil Pump
If you want to start jet-hot coating and cryo-treating or even go with a custom bore or stroker kit you are adding thousands to that. The point we're making is that you can easily spend just $15K on the motor alone without a turbo kit. It isn't necessary for everyone but he asked for fully built. Also, Gman is the foremost authority on how to spend money on a VQ. Take it from people who paid the cost. I haven't done it on a VQ yet but my VG had similar pricing.
Old Jan 25, 2006 | 09:29 AM
Navygolf13's Avatar
Navygolf13
All I am saying is that I built a motor that put 505 to the wheels, granted I had the TT kit already, but I only spent $11,000 and it was done right. Church Automotive was very impressed when I had it tuned. I think you guys are right that it depends on "fully built" but when you do it there should be no way that it should be $20,000 as long as you are looking for something in the neighborhood of 500 to the wheels. If you want to go that extra mile then sure you can spend $50,000 on it too. All I am saying is that you can get a TON out of your motor for less than 15k!
