Which EMS to buy?
Old Jan 26, 2006 | 07:21 PM
Alberto's Avatar
Alberto
Cranky FI Owner
Originally Posted by MRC Motorsports
..And FWIW the AEM is still being tested on the DREAMWORKS supercharger car.
Lol-I love how brutally honest/smart a$$es you MRC guys are
Old Jan 26, 2006 | 08:31 PM
Poptarts's Avatar
Poptarts
well getting something thats a boost controller is not what im worried about. i have a Greddy E-01 bc for that.
im looking for something that will give me the ability to switch between a racegas tune and a regualr driving tune. currently im in lubbock, 500 miles or 8-9 hours away from houston, and i cant be traveling back and forth to houston every time i want to get a tune.
i am also looking for something that will give me full control of the o2 sensors. im sure as most know, the problem with running racegas(leaded) is that it destroys your o2s. i dont have cats so i can run leaded.
i guess in everyones opinions, should i go return fuel system, EMS, or transmission, because they all seem to end up being about the same cost but each yield different results?
Old Jan 27, 2006 | 11:48 AM
1G-350Z's Avatar
1G-350Z
Originally Posted by mistaboosta
just wait for the Hydra EMS. Hydra Ver. 2.5 will be available as a plug&play ecu for 350z soon. I used utec and AEM EMS on my ex car. They were both great systems but both have some problems. UTEC falls on its face when you stroke your engine or install some agressive cams (can't tune idle so well, can't change the map for the off boost load points etc.), AEM's problem is that it is a lil bit complicated and not user friendly but it is a very good solution. If cash isn't a problem go with the MOTEC M600 or M800, you will have to ask someone to make a harness for that. MOTEC will be around 5500-6000 $ when everything is complete and your car is tuned. As a conclusion, i'd reccomend going with HYDRA EMS as it is only 2500$, has great control over your engine, very user friendly and have good base maps.
I've herd really good things about the Hydra system... Hope it comes out soon.
As far as Motec isn't that too much for a street car, I thought it was a true stand alone, and you would loose all your VDC/ABS/climate control/ etc...
As I understand it Hydra is a full Stand alone, the VDC/ABS/climate control etc. is already recorded on the Hydra EMS, with tunable base maps for engine control.
Old Jan 27, 2006 | 02:39 PM
Julian@MRC's Avatar
Julian@MRC
The UTEC can do this without the addition of an expensive boost controller such as the profec-1. The UTEC can map boost and control it via a BCS.
Old Jan 27, 2006 | 02:42 PM
nightfire's Avatar
nightfire
How many times/how much do you have to spend on a tuning after you guys TT your cars to make them idle and run correctly? (running well, not just running). My friend had a newer eclipse that he S/T'd and he said the tuning was a nightmare and the car was never the same again. It was really hard to start in cold weather and was always finiky and never reliable...
Old Jan 27, 2006 | 03:04 PM
Julian@MRC's Avatar
Julian@MRC
My car was tuned once on the UTEC and idles better than stock with 650cc injectors..For some reason my stock Z always had a misfire at idle...MY A/F is 14.7 at idle..Maybee cause your friend uses a super AFC???Or whoever tuned it had no clue what they were doing?
Old Jan 27, 2006 | 03:40 PM
Brandon@Forged's Avatar
Brandon@Forged
Forged Internals.com
I would strongly recommend the emanage ultimate or TurboXS UTEC over the other options.
Old Jan 27, 2006 | 05:25 PM
ChunKy350Z's Avatar
ChunKy350Z
Haltec :d
Old Jan 28, 2006 | 10:03 AM
paranormal's Avatar
paranormal
Evil Boy 4 LIFE
ill come play when is the march thing? yall got a date? hopefully my car will be all tuned up and ready by then..
Old Jan 29, 2006 | 05:21 AM
mistaboosta's Avatar
mistaboosta
That is not true, the utec allows for the scaling of the injectors and timing at idle, and in future software updates will give it the ability to raise idle..And FWIW the AEM is still being tested on the DREAMWORKS supercharger car.
We have had ZERO issues getting cars started and running on the UTEC..
I was talking about stroked engines like AEBS shortblock etc. When you stroke your engine you cant hold on the standart 14.7 afr for idle, you have to shoot lower numbers like 13.8-13.5 and if you got some very agressive cams you will have to shoot even lower. You can not do this with UTEC as much as i know (when you try to do it with utec you need to change all the off boost load points just to tune idle). 650cc injectors are okay but how about some 850cc injectorS? How about tuning map load points when overlapping occurs with agressive cams? These are not controllable with UTEC sorry
Never said AEM is released.
Good to hear that soon UTEC will be available to raise idle.
UTEC is the best system (not only for Z but also all the other cars that UTEC is available) if you aren't going for something extreme. When you go extreme by upgrading stock turbos with much larger ones, really big injectors (>650cc), stroker engines, agressive cams, then you need a standalone.
Old Jan 29, 2006 | 05:47 AM
Jokestrap's Avatar
Jokestrap
My car is at SGP right now. I went with V-Pro. If you ask for the best, V-Pro is what you will get from SGP.
Old Jan 29, 2006 | 07:08 AM
Julian@MRC's Avatar
Julian@MRC
THe UTEC as controlled 750cc injectors on my car no problem..Correct me if I am wrong, but if your cams overlapped, you would not build compression in the motor, cause you would be opening the exhaust and intake valves at the same time..
Old Jan 29, 2006 | 07:10 AM
Julian@MRC's Avatar
Julian@MRC
Of course, and if I walked into a car dealer and asked for the best, I would drive out in a $300,000 Bently..That does not mean I NEED it.
Old Jan 29, 2006 | 07:56 AM
Gumpdriver's Avatar
Gumpdriver
I Just bought my UTEC yesterday from MRC man they are great people to deal with.But i can not wait till i get the UTEC in and go to Sharif and get it all tuned up.
Old Jan 29, 2006 | 09:46 AM
mistaboosta
that's right, it can be solved by playing some tricks about timing with standalones.
nice to hear that utec can control 750cc injs without a problem.
Old Jan 29, 2006 | 10:27 AM
MI 35th's Avatar
MI 35th
OGPremierMafia
I say for current go with UTEC, user friendly and reasonably priced... Ive had personal experiance as a user, tweaking systems on AEM, TXS, and Hydra. I have nemesis on the MR2 and love it beyond what i thought even i would. it came down to myself and another owner who has AEM who has recently ditched for Hydra. we made similar power but mine was uned in far less time...
i cant decide because unless ou are goin for crazy like 800+ hp i dont even see why a Utec wouldnt cover you. Id prolly have gotten it for the MR2 if avl.
Old Jan 29, 2006 | 05:42 PM
  #38
Poptarts's Avatar
Poptarts
well just to let yall know i bought the F-CON SZ from HKS. it uses all the same harnesses as the VPRO but is like the e-manage ultimate. with a tune and all the necessary harnesses my total is coming out to $2000
Old Jan 30, 2006 | 04:59 AM
  #39
Guru's Avatar
Guru
I would recommend the UTEC for most people. The F Con V Pro is an excellent ECU but about the same price as a full Motec M600 by the time you add everything up. Motec is, as many folks will tell you, the ultimate but overkill for most street cars. Also setting up and tunning any standalone setup is going to take far longer and cost far more than tuning a UTEC which can be done in 1-2 hours. I have spent an entire day and then some tuning a Motec from scratch. Another great option is the Hydra which will bring a standalone system into the affordable range but sadly is not yet available. No ETA.
Justin100
Nov 25, 2021 06:26 AM
Alexreyes
Sep 30, 2015 11:30 PM
KOF
Tuning
Sep 30, 2015 04:09 AM
