Anyone make a g35 rad yet
Old Jan 30, 2006 | 12:02 PM
meatbag's Avatar
meatbag
Default Anyone make a g35 rad yet
I was going to use a PE and modify it to fit but they are backorderd till late feb and i cant find anyone that has one in stock. So any knews on a rad from PWR or anything else?
Old Jan 30, 2006 | 12:17 PM
Zivman's Avatar
Zivman
I thought Koyo made one, but mayabe not. The z one can be modified to fit
Old Jan 30, 2006 | 01:51 PM
Gman2004's Avatar
Gman2004
the koyo requires much more work than the pe for the G35. The koyo requires the shroud and fans to be cut, as well as relocating the top mounting brackets. the pe only requires the top mounting brackets relocated. other than that it is pretty much a drop in.
I got mine through Sharif. You may want to check with him if you haven't done so already.
Old Jan 30, 2006 | 02:02 PM
barthelb's Avatar
barthelb
Master
Call ZcarGarage, they have done about 4 or 5 G35's and I don't think they do too much work its maybe a 1 or 2hr job at that. Maybe they can help you out. 408 452 0350
Old Jan 30, 2006 | 02:11 PM
meatbag's Avatar
meatbag
Im going to call him tomarow when hes open again and see. PWR said they would make one thats a direct replacement in the G35 so im going to try that first.
Tochigi_236
Sep 27, 2015 03:40 PM
