GM400 Adapter Plate - BRANDNEW!!
Old Feb 4, 2006 | 09:33 AM
Nizmo1180's Avatar
Nizmo1180
Default Bump
Bump...
Old Feb 4, 2006 | 10:03 AM
Fairlady_z33's Avatar
Fairlady_z33
I think we need more info and more options to other trannies cause i think some peole might want to keep the AT's as daily drivers for some fun street racing if they do it.
Old Feb 4, 2006 | 04:32 PM
overZealous1's Avatar
overZealous1
Originally Posted by overZealous1
the 700r4 could be bolted up to that housing too. but the mount would be different. tons of them out there and they can be built up pretty high (not quite as much as the glide or 400turbo though) just give you the nice overdrive if you still cruise the street alot.
now just out of curiousity, do you guys have a solution for guys still running the factory ecu with this trans swap? speedo conversion, and the like. or is it going to be for all out racing and standalone ecu's?
ya, i think ya skipped all the questions i had also.
Old Feb 4, 2006 | 04:45 PM
Fairlady_z33
I would like to keep the Z's AT tranny since it has the triptronic option which is alot of fun but no one still is able to upgrade the tranny to hold power. But i also want performance becouse if you want a serious 1/4 mile monster you need that fully built AT.
BTW keep us informed on what other options we have for other trannies thanks.
Old Feb 6, 2006 | 05:04 AM
Nizmo1180's Avatar
Nizmo1180
Default GM Turbo 400 Adapter Kit...
I will post a full comprehensive explaination of what needs to be done to use a turbo 400 tranny. Its not as complicated as you may think, but does require modifications. I appreciate your patience, and will post a complete overview shortly
thanks,
Nick
PM, NY
Old Feb 6, 2006 | 03:59 PM
InjectedPerf's Avatar
InjectedPerf
Injected Performance
The Turbo400 is a streetable transmission. There are two options, one with the transbrake and one with the lock up converter. The latter of the two is what most people would go with. The transbrake option would be used for the serious drag racer. The Turbo400 with lockup and a 6 speed differential is what most Supras run on the street. I would have to guess that this setup would also be very good for the Z. Just need to play with rear end ratios.
The Turbo400 does soak up power. Depending on the horsepower numbers you are looking for, you can go with the Turbo350 which does not soak up as much.
We are putting a Powerglide or Turbo400 in one of our 350z's and already run one in our 1100rwhp Supra
Old Feb 6, 2006 | 06:25 PM
overZealous1
it has been a long time since i have messed with a t400. they have lock-up converters for them now? like a 4000 stall with a cruise full lock up switch? they use a different valve body or something? i know the 700r4's do and the newer style 4l80e's. or were you referring to just the normal lock up stall speed? i know the glide and t400 can be built a bit more stronger and a little cheaper than the overdrive versions of 3 speeds. been a couple years since doing a overdrive though, so they might have come out with more stuff for it now though.
can't wait to see the tech write up on this. i like the 6 speed, but nothing like just putting your foot to the floor and constantly being in the power band with no shifting losses in high hp cars.
Dsowe
Feb 17, 2021 10:38 AM
kyin
Oct 15, 2015 05:54 AM
EnjukuRacing
Sep 30, 2015 06:55 AM
