Cylinder 5 Misfire code??????
Old Feb 12, 2006 | 03:04 PM
  #101
D350Z10's Avatar
D350Z10
I understand where everybody is coming from, to start things off my WG is not located at the factory position, and once the boost solonoid and utec were installed It held 9.5 psi all the way to 5000 rpms and car ran great. What I don't understand is How did this just randomly come up???? All of the info is out on the table. THIS HAPPEND RIGHT AFTER the injectors were installed the car was on for a while and then the light came on. The reason why a leakdown test wasn't performed is because the tuner said he would find a exact answer with the engine out and apart, a leakdown would just tell the area. And the feel that the area is already determined and that is the piston.
Old Feb 12, 2006 | 07:40 PM
  #102
overZealous1's Avatar
overZealous1
Originally Posted by JETPILOT
I was told that a crude form of a leakdown could also be performed using a compression tester and noting the drop in pressure during the first 20 seconds after engine cranking. No?
Respect
JET
you were doing a leak down test on the seals of your compression tester, lol, not the cylinder.
Old Feb 12, 2006 | 08:53 PM
  #103
JETPILOT's Avatar
JETPILOT
F*CK !!!!!!
Last time I ever take someones word at face value !!!!
Respect
JET
07ZEKE
Aug 23, 2021 09:15 PM
sherm
Apr 11, 2020 05:21 PM
derekinthez
South East
Sep 28, 2015 06:35 PM
Detailed Image
Cleaning & Detailing
Sep 28, 2015 03:03 AM
