305 Rear Tire ???
Old Feb 16, 2006 | 11:10 AM
  #41
sentry65's Avatar
sentry65
the burninator
my 295 PS2's do ok I guess.
I think I was expecting a lot more though so I feel a little let down. They're vague in the corners compared to some other tires because the sidewalls flex more.
the inside of the tire is developed more for wet traction and the outside of the tire is developed more for dry traction. Kinda sucks though since the Z has some camber going on in the rear so your contact patch is the more of the wet traction part of the tread
you guys really need to check out the tire size calculator
Also keep in mind that wheels that are different widths by .5 inch increments have an effect on the same tire by varying the buldging by .2in (5mm).
So a 9.5 rim with a 285 tire will be .4 inches less wide (at the bulge, not tread) than that tire on a 10.5 rim
BTW, why isn't this thread in the wheel/tire section? What's with all the 275mm tires with 400+hp FI Z's? Why does everyone go for those sizes? Is it the wheel choices? Is bling more important than traction? Did people make a consious decision to get a 275 and not a 295?
Old Feb 16, 2006 | 12:50 PM
  #42
D350Z10's Avatar
D350Z10
Originally Posted by D350Z10
Great Thread... I have been looking into this for SO long and havn't came up with any answers....
BEST SIZE for NISMO lmgt4 18's 18 X8.5 FRONT and 18X9.5 REAR... Right now my tire setup is 245-40-18 and 275-40-18.. I want to fit 295's or 305's best setup anyone??????
ANYBODY??????????????????
Old Feb 16, 2006 | 01:22 PM
  #43
GMADD's Avatar
GMADD
I'm not sure that a 305 tire would fit on a 9.5 wheel but I could be wrong.
Old Feb 16, 2006 | 01:35 PM
  #44
barthelb's Avatar
barthelb
Master
In VRT's defense they say they have and that it works fine. From my own experience Im running a 285/35/19 on a 9.5 +33 offset. Rule of thumb is you can go 10mm wide and reduce the side wall by 5% and you should not affect the overall tire diameter or width to much. I think by the way the 285's fit that a 305/30 should fit and have a normal buldge like on some cars. I'll know if about 2 months when my tires are gone.
Old Feb 16, 2006 | 09:16 PM
  #45
taurran's Avatar
taurran
I think its more of an issue of fitting the tire in the fender well with the very aggressive offsets that look good on our car. On a 19x10.5in +24 or +22 offset wheel, once you go higher than 285 you're going to be cutting or rolling fenders. Also, if you address camber it's just going to be that much of a tighter fit. Most folks will only compromise on looks so much.
Old Feb 17, 2006 | 01:17 AM
  #46
prescience's Avatar
prescience
Some useful info here and a couple of great calculators; the second one should be able to answer your question
http://www.carbibles.com/tyre_bible.html
Old Feb 17, 2006 | 07:42 AM
  #47
ReV2Red's Avatar
ReV2Red
I haz da turbos
Just a quick note for everyone. I think i said it before, but you know that the wider you go with your tires, the more you have to lower the pressure in your tire in order to keep the same contact patch, or improve it. If you go too wide you will get to the point where you you have no air in the tire (exageration, but you get the point).
Old Feb 17, 2006 | 07:48 AM
  #48
theking's Avatar
theking
Uh, OK. Where did you get this info?
Old Feb 17, 2006 | 08:04 AM
  #49
ReV2Red's Avatar
ReV2Red
I haz da turbos
I think i remember somebody in this forum posting a really good website about tires and wheels. It actually makes sense, because as you increase the width of the tire, you are distributing the weight of the car over a larger area, and therefore less pressure on the ground, and therefore less contact patch. So to overcome this you have to reduce the pressure in the tire to actually increase the contact patch.
Old Feb 17, 2006 | 08:10 AM
  #50
prescience's Avatar
prescience
If you checked the link I posted a few posts back about in 'Fat or Thin - Contact Patches and Grip' section of that you'll see that the area stays roughly the same but the profile (shape) changes when you change tyre width
If you lower the pressure in either case, you will get more contact area
Old Feb 17, 2006 | 08:40 AM
  #51
ReV2Red's Avatar
ReV2Red
I haz da turbos
That's the one, i knew it was something along those lines, thanks for clearing that for me
Old Feb 17, 2006 | 02:53 PM
  #52
comebackZ's Avatar
comebackZ
Not F/I yet but I will be running 315s and probably 335s when I get money to buy another set of wheels for track use. The wheels I got now are just way to pimp and I got a deal too good to pass up with them.
