best TT kit for drag racing??
Old Feb 19, 2006 | 07:31 PM
  #61
WSchli1672's Avatar
WSchli1672
Not to get involved, but I believe the challenged should have choice of location and the chalenger can set the date and time for convenience of being workable. Il and Mi are close together, so if it happens, please post it on the board (i.e. time slips, pictures). I'll have to give the APS TT the advantage though, but would love to see it happen.
Old Feb 19, 2006 | 07:39 PM
  #62
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
Originally Posted by D350Z10
US-131 sounds good, never heard of it but sure. and yes Bfgoodrich drag radials, 275's only, no I am planning on running a street 305 tire in the rear.
When spring rolls around and weather is good Ill send you a pm. Car will be free from all shows and other stuff then.
Have any timeslips of your car pulling 1.7s N/A?? Definitely get in touch with me when it warms up, I'll be ready and should be quicker than last year with the increase in power.
Old Feb 19, 2006 | 08:37 PM
  #63
georgec's Avatar
georgec
Originally Posted by BriGuyMax
I will say this, a twin turbo setup is easier to control because of the more linear powerband. You don't have boost suddenly coming on like you do in a single turbo setup.
100% correct. It's the sudden change in power/boost output over a small rpm range (a huge difference in power over a 400 rpm range, between 3600 to 4000 rpm) that makes traction really difficult for a single turbo at the strip, the twin turbos will always have a distinct advantage and a more linear/easier to handle power band at the strip as you correctly stated.
It's easy to see that you have a load of experience at the strip, your comments are always dead on right and you have the ET and MPH behind you to back up your comments.
George
Old Feb 20, 2006 | 03:38 AM
  #64
BlueMeany's Avatar
BlueMeany
Ok, Ill say this. I want to comfortably drive my car everyday and go to the track when I get a chance and actually get descent runs ( 11's-12's). I don't really care about being CARB legal. They don't check for that down here (new orleans). and I know all kits can e harmful to your engine, but I would like my engine to last for a while and not blow up the day after I do my first runs at the track. That's a little more specific.
Old Feb 20, 2006 | 05:54 AM
  #65
D350Z10's Avatar
D350Z10
Sounds good, Ill send you a pm when time comes. My car should be fully tuned and good to go! What tires and octane will you be using? stock block?
Old Feb 20, 2006 | 06:13 AM
  #66
taurran's Avatar
taurran
Wow this thread really went to sht...
Old Feb 20, 2006 | 06:25 AM
  #67
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
295/35-18 BFGs and pump gas...completely stock motor.
Old Feb 20, 2006 | 12:49 PM
  #68
mrtomcat's Avatar
mrtomcat
I would then highly recommend the APS TT, it does get you into the 11's, is a great smooth daily driver and has an amazing track record in terms of reliability
Old Feb 20, 2006 | 11:52 PM
  #69
JisNis's Avatar
JisNis
Briguymax,
What mods do you have as of right now running your 10psi?
Old Feb 21, 2006 | 08:22 AM
  #70
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
Originally Posted by JisNis
Briguymax,
Nothing special...APS TT kit, helix test pipes, Borla TD exhaust, JWT clutch/flywheel...I think that's it.
Old Feb 21, 2006 | 09:45 AM
  #71
JisNis's Avatar
JisNis
Im sold on the APS TT.
apex locator
Jul 23, 2021 02:27 AM
EnjukuRacing
Sep 30, 2015 06:55 AM
