Looking at Supercharged 350Z...Questions inside
Old Feb 21, 2006 | 11:55 AM
Torched Z's Avatar
Torched Z
Default Looking at Supercharged 350Z...Questions inside
what are some of the common problems i should look for?
2003 vortec supercharger with 18000 miles
looking at the vehicle today i need to know what to look out for
Thanks in advance!
Nikita
Old Feb 21, 2006 | 11:57 AM
chimmike's Avatar
chimmike
did you by chance take a second to read a couple threads before posting this?
namely the "Vortech sucks" thread that was at the top of this list when you started this thread?
Old Feb 21, 2006 | 12:01 PM
Torched Z's Avatar
Torched Z
I've been searching for a little while now, but it's hard to find directly related posts.
Is the problem posted in the "vortech sucks" thread a common one?? I cant seem to find a good answer.
Thanks,
Nikita
Old Feb 21, 2006 | 12:16 PM
dixieland's Avatar
dixieland
man - probably not a good day to be asking about Vortech problems! There are some that are happy and some that are currently not very happy (hope that was diplomatic enough for everyone!). SC are going to make noise, some more than others. All up to what you are comfortable with.
Without giving an opinion on the SC itself, i would strongly suggest you take the car to someone who knows SC's etc to have it checked out THOROUGHLY before you sign on the dotted line.
Probably not very helpful..but good luch and welcome
Old Feb 21, 2006 | 12:59 PM
350z_this's Avatar
350z_this
well.... not ALL sc makes a lot of noise..... Stillen doesn't make any noise except for the sound of a jet taking off........ but you end up with an ugly hood.......sigh....... can't win them all.......
Old Feb 21, 2006 | 01:46 PM
booger's Avatar
booger
If you search any of thr kits , be it a SCer or a turbo kit . You will find that people have problems with every kit . Its the nature os modding cars . I can tell you about some of the problems you MIGHT run across with the Vortech . And I repeat.....MIGHT.... Although its not a problem , you may have to tighten the serp belt every few weeks . The owner may have already changed to the thicker Gates belt that doesnt stretch as easy . The blower may make a noise when at idle that sounds like a bad bearing . Gg8tor20's noise is much louder than others . Some complain about the whistle the bypass BOV makes at cruise and idle [ some like it ] Im sure there are other problems Im for getting about . I just got up from sleeping and not to awake .
The turbo kits will have problems also ...smoking , boost creep , boost fall off , and others Ive read about and cant remember about also .
You are changing the way the car was designed to run when you mod it . There will be provlems to over come
Old Feb 21, 2006 | 02:20 PM
sentry65's Avatar
sentry65
the burninator
i wouldn't be too far turned off of the vortech because of Gg8tor20
Old Feb 21, 2006 | 02:34 PM
g8tor20's Avatar
g8tor20
No...the vortech ran great when it ran well. It developed a problem and I had a hell of a time getting it resolved. If it runs like its supposed to...it works great and is a blast to drive. Mine was too loud and embarrasing to drive with. All S/C has a slight rattle at idle...but mine was crazy loud and some part was defective. Like others have said..check it out firsthand.
Old Feb 21, 2006 | 05:42 PM
zachcrosen's Avatar
zachcrosen
I have had the belt slippage issue once in about 7 months that I have had the Vortech SC. I like the kit in general. I just wish I had more torque, but thats just the nature of a SC.
I have a slight rattle as has been mentioned, but I can live with the added noise for the added HP! At times, the bypass valve is annoying, but I can also live with it for the added power.
One problem that is mentioned every so often is about the filter. On the Z, it is extremely hard to remove to clean. As a matter of fact, I have not been able to get mine out in almost 10k miles. There are some members working on filter relocation kits at this time which will give easier access to change the filter.
In conclusion, any time you have a motor do more than it was designed to do, there will be problems. I have had minor issues that have all been worked out and/or are being worked out. The Vortech is one of the safest forms of F/I and it provides great power gains. I say go for it!!
Cant argue with 367RWHP and about 305RWTQ out of an automatic!!!
Old Feb 22, 2006 | 08:39 AM
dimebagdolf's Avatar
dimebagdolf
I had my Vortech done in October, I've got 18k mi on my Z as well.
No probs whatsoever. Z Car Garage did mine, and they've really learned how to do the Vortech install right. I've had zero problems with mine.
Old Feb 22, 2006 | 03:11 PM
CpraceZ's Avatar
CpraceZ
We have installed several vortech kits here at the shop, and haven't had any problems, there kit is well put together and makes very good power. Also they have very good customer service so if there ever is a problem they always get it fixed. I would recommend getting 1 stage colder plugs with the kit, and also suggest a clutch if you still have the stock clutch, the stock clutch may or may not hold. If you have any question feel free to PM me, but yes it is a great kit and I highly recommend it.
350Z_Al
Oct 29, 2020 07:44 PM
3vilbunny
Jul 18, 2017 05:10 PM
Justin100
Nov 29, 2015 03:58 PM
kyin
Oct 15, 2015 05:54 AM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
