Turbonetics AT w/ cat = 328 hp & 324 tq???
Old Feb 22, 2006 | 05:17 PM
jlimquest's Avatar
jlimquest
Unhappy Turbonetics AT w/ cat = 328 hp & 324 tq???
Just got off the phone with my shop. Mustang dyno at 328 hp & 324 tq. Max boost was steady at 8lbs. w/ AF at mid 10's (rich). Besides being a 5AT w/ TN CAT version I also have a 5/16 spacer, Jet Hot coated stock headers, Injen dual exhaust & UR pulleys. Does this look right??? Any assistance is appreciated....HELP PLEASE...
Old Feb 22, 2006 | 05:19 PM
D350Z10's Avatar
D350Z10
I gotta believe thats not corrected? please post dynos. gotta see the power curve, if it is pretty straight no problems such as boost leaks and chit. They pry just gave you uncorrected numbers.
Old Feb 22, 2006 | 05:33 PM
MIAPLAYA's Avatar
MIAPLAYA
Couple things...first Mustang dynos tend to read kind of low. Second the cat is definitely not helping performance. I'd love to see what it makes without that cat..
Old Feb 22, 2006 | 05:34 PM
Bubble's Avatar
Bubble
-REPLICA ARMY-
bring to a different tuner to check out yet?
Old Feb 22, 2006 | 05:44 PM
jlimquest's Avatar
jlimquest
BTW, my base dyno before TN was 248 hp & 234 tq....also, why is my AF at mid-10's...Is that causing power loss?....should I send back my ECU & reflash at TN or Technosquare???....Thanks, Jeff
Old Feb 22, 2006 | 05:50 PM
MIAPLAYA's Avatar
MIAPLAYA
No the AFRs tend to be a little low the first day or so. That cat is most certainly causing some backpressure that is hurting peformance. I'd say with the cat, on a 5AT car, on a Mustang dyno those numbers aren't bad. How does the car feel to you?
Old Feb 22, 2006 | 05:59 PM
jlimquest's Avatar
jlimquest
Haven't driven it yet....just talked to shop this afternoon. I'll try to get the dyno faxed so I can post.
Old Feb 22, 2006 | 06:18 PM
Zivman's Avatar
Zivman
considering you are running an auto and a cat version dp, those numbers on a mustang dyno aren't that bad. From the cars I have seen run between a mustang dyno and a dynojet, it is roughly an 8-10% lower reading on a mustang. Taking 9% and adding it back in, you are at approximately 360 whp (dynojet).
Now, you also need to factor in you are running an injen exhaust that must be custom fabricated to fit a single downpipe. I don't consider the injen a very good exhaust for a turbo setup to begin with, considering the size of the piping.
I personally wouldn't be too disappointed with those numbers
edit:
Were your base dyno #s from the same dyno as the TN #s?
Old Feb 22, 2006 | 06:35 PM
jlimquest's Avatar
jlimquest
No, my base dyno was from Powertrain Dynamics in Huntington Beach. They used a Dynojet 248E Chassis dyno.
Old Feb 22, 2006 | 06:39 PM
Zivman's Avatar
Zivman
Considering you have an auto, even on a dynojet, I think those base numbers are a bit high. Take the car back to that dyno and give it a run, I bet you will see numbers closer to your expectations.
In the end, they are just numbers, so don't be dissapointed until you at least drive the car.
Old Feb 22, 2006 | 07:18 PM
MIAPLAYA's Avatar
MIAPLAYA
Agreed if those baseline numbers are from a Dynojet and not the same dyno that was used for the post install dyno you can't really rely on those. In checking gain you need to do a baseline before install and then post install dynos HAVE to be done on the same dyno as the baseline. Its the only way to accurately measure gain. I'm sure as Zivman said the numbers would be more what you expect if you go back to that other dyno.
Old Feb 22, 2006 | 07:21 PM
Alberto's Avatar
Alberto
Cranky FI Owner
Not bad at all considering the cat+auto+Mustang dyno....like stated, go back to where you got your first baseline and report back.
Old Feb 22, 2006 | 08:41 PM
G352NV's Avatar
G352NV
Let me ask you this. How does the car feel?
Old Feb 22, 2006 | 08:54 PM
MIAPLAYA's Avatar
MIAPLAYA
Old Feb 23, 2006 | 12:28 AM
S12 driver's Avatar
S12 driver
If you're running rich at 8 psi, maybe you can up the boost to 9.5 psi and see if you get a bit more power out of it.
Old Feb 23, 2006 | 06:18 AM
MIAPLAYA's Avatar
MIAPLAYA
I wouldn't. Most cars will run a little on the rich side out of box for the first few days. Should lean out to around 11s or so and stay there. ECU needs to adjust its timing based on knock detection.
Old Feb 23, 2006 | 03:52 PM
AReddy23's Avatar
AReddy23
something similar happened to me on a mustang dyno, get on a dynojet asap.
Old Feb 25, 2006 | 03:30 PM
hypeiv's Avatar
hypeiv
Don't get bent out shape over a dyno. Take it to the track and see what your trap speed is.
Old Feb 25, 2006 | 07:24 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Perfectly normal for a mustang dyno. I am willing to bet this is close to 375whp+ on a Dyonjet. I went through this with my car, on a local Mustang dyno a while back. 327whp on the mustang, and 407whp on a dynojet...one day apart.
durangorider
Dec 1, 2008 04:13 AM
psheehan
North East
49
Sep 18, 2008 12:31 PM
350 Rookie
Jan 27, 2008 08:35 PM
jdm3fiddyZ
Mar 30, 2006 05:41 PM
35ounces
Jun 10, 2005 09:54 AM
