Turbonetics AFR, EGT & BOOST gauge readings???
Old Mar 6, 2006 | 09:10 PM
jlimquest's Avatar
jlimquest
Default Turbonetics AFR, EGT & BOOST gauge readings???
Hey Guys,
What are the acceptable (meaning safe) AFR, EGT & Boost gauge "range" readings for the TN kit at idle, cruising speed, acceleration, WOT & deceleration? BTW, this is with stock internals.
Thanks,
Jeff
Old Mar 7, 2006 | 06:33 AM
MIAPLAYA's Avatar
MIAPLAYA
It all depends on car and gas used but typically:
Cruise under vacuum AFR could be from 13-12 EGT depends on where yours is but mine is between 600-800
Under boost AFR should be 12s at 1 PSI dropping to 11s or 10s quickly. EGT Typically from 750-1200 depending on where your probe is.
Old Mar 7, 2006 | 06:35 AM
chimmike's Avatar
chimmike
at 8psi with my mods, the a/f is either 10.8 or 11:1 solidly. Vac at idle is close to 25, and cruise is totally dependent on your throttle position.
Old Mar 7, 2006 | 01:46 PM
Peking's Avatar
Peking
Originally Posted by jlimquest
Hey Guys,
Thanks,
Jeff
A/F sorta varies but we all try to keep in the same area of low-mid 11's WOT, out of boost mid-high 14's sometimes into the low 15's depends cause it is jumpy. EGT also depends, like were the probe is placed though I seem to be in the areas of where MIAPLAYA and Chimmike have stated.
Old Mar 7, 2006 | 02:41 PM
vitaminZ's Avatar
vitaminZ
+1 For the AFR on my TN Z. no EGT on my set up.
Old Mar 7, 2006 | 08:08 PM
lucidazn's Avatar
lucidazn
My AFR starts at 11 @ WOT and climbs to 11.8 quickly and stays spot on there.
Old Mar 8, 2006 | 05:49 AM
jlimquest's Avatar
jlimquest
My AFR goes from 14-17++ when decelerating & 14-15 on cruise. At WOT it is at 10.5. Is that within normal guidelines? Also, what should it be at idle? THANKS ALL!!!
Old Mar 8, 2006 | 06:17 AM
MIAPLAYA's Avatar
MIAPLAYA
When you decelerate its not uncommon to go lean. When the BOV opens you are exeplling all the air in the intake tract and therefore no fuel is added. Idle should be 14.7:1 steady with occasional jumps into the 15s. Everything sounds fine to me.
apex locator
Jul 23, 2021 02:27 AM
kyin
Oct 15, 2015 05:54 AM
codek
Sep 28, 2015 03:03 AM
