Exhaust Smoke
Old Mar 10, 2006 | 04:43 PM
KTaylor's Avatar
KTaylor
Default Exhaust Smoke
I have a dual exhaust on my TT Z and smoke comes out of just the drivers side of the exhaust. what would cause that? the reason i ask is because weve been having some problems with how the cars been running latley and was wondering if theres something i should be looking for. Thanks
Old Mar 10, 2006 | 04:48 PM
BoOsTedz33TT's Avatar
BoOsTedz33TT
you probaly blew something up ...compression and leak down test
Old Mar 10, 2006 | 05:16 PM
350zDCalb's Avatar
350zDCalb
builtZmotors
do you see the smoke during any specific time?
acceleration?..decel?, idle..worse at start up first thing in the morning?
several possibilities... turbo seals, piston rings, damaged pistons, valve stem seals...
just like said above, do a leakdown, this will be the most conclusive test, even though, at times a leakdown can show a false negative (showing everything is ok)...a compression test has a MUCH higher probability of displaying a fasle negative, for this reason, put your emphasis on a leakdown test to start the investigative procedure.
-TODD
Old Mar 10, 2006 | 07:11 PM
KTaylor's Avatar
KTaylor
during acceleration and idle so pretty much all the time. thanks for the input ill let u all know what we find.
sales@czp
Sep 23, 2019 03:30 PM
Justin100
Nov 29, 2015 03:58 PM
Sleeper_Z
Sep 30, 2015 10:25 AM
Li1ag
Sep 28, 2015 02:07 PM
