how lean is too lean?
Old Mar 15, 2006 | 11:53 AM
dirtroad's Avatar
dirtroad
Default how lean is too lean?
I was going over some data logs and noticed that my 3rd gear AFR ratios are in the 12's for the most part. Once I go up to 4th gear, the AFRs get down into the 11's. Are the lower gears (1, 2 & 3) supposed to run leaner than the higher gears? If so, what would be a good Air/Fuel ratio for each gear? I'm non-built running the APS single turbo.
Old Mar 15, 2006 | 02:16 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
12's at lower RPM, and WOT are fine, but I'd like to see your AF ratios dip into the 11's beyond 4000rpm. In gears 1 and 2, you are under much less load, so its not uncommon to see slightly leaner AF ratios, and obviously..less boost pressure.
Old Mar 15, 2006 | 05:33 PM
dirtroad's Avatar
dirtroad
sweet...
pdexta
Sep 14, 2015 11:27 AM
Chebosto
Aug 6, 2003 06:31 AM
Oh4aZ
Mar 28, 2003 12:35 AM
menehune
Feb 14, 2003 05:11 PM
