Turbonetic Dyno 350z At
It looks like that's where he started the dyno pull. FYI your stock motor doesn't make that much horsepower at 3500rpms. Torque is what you compare at lower rpms.
Originally Posted by streetracer
The horsepower in the diagram states 165 at 3500. Does the FI kits loose that much power at the bottom end?
The ST does because it is still making enough boost to offset the backpressure.
So, comparing torque curves for na vs. FI, which one makes more torque at 3500 rpms?
wanderingstuden
Jan 28, 2016 07:03 PM
Justin100
Nov 29, 2015 03:58 PM
2004, 350z, 70297, automatic, bm, cooler, cooling, dyno, g35, hitek, oil, transmission, turbo, turbonetic, turbonetics
