Which Radiator for FI Z
Old Aug 28, 2006 | 06:50 AM
  #61
blackend's Avatar
blackend
guys our car with is middel east the radiator size is 28mm cause in our countery the temp reach 48C so if you buy the our OEM radiator will be best for you cause it is stock for you
Old Aug 28, 2006 | 09:36 AM
  #62
350Zteve's Avatar
350Zteve
That's a good option if the non-North American radiator can be purchased from Nissan. I believe JDM Z's get this two core factory radiator as well.
Old Aug 28, 2006 | 08:51 PM
  #63
Weqster's Avatar
Weqster
i'll have to measure the size of the rad down here in aus. i suspect same as the american market though.
Old Aug 28, 2006 | 09:08 PM
  #64
mchapman's Avatar
mchapman
Originally Posted by MoodDude
There is no water ran to the APS turbos. APS only connects the oil to the turbo's and this actually cools the turbo's. I have installed an oil cooler for this reason. Yet, since I am making twice as much hp than stock, I need a radiator that will take all that extra heat away from the engine.
Your thinking of PE. They run water cooled turbos but dont connect the water lines.
APS run water cooled turbos and connect the lines to your existing coolant system.
Old Aug 28, 2006 | 09:41 PM
  #65
AmyCroft's Avatar
AmyCroft
Smile Weqster - AU 350Z should have the JDM dual Core
I read if I remember correctly you have a dual core in AU. As the JDM and EAU
cars have. It would appear only the USDM and Euro car's have the single core.
As far as Koyo's go, a dual core can be fitted with a minor trim of the mount. Very little cussing.
However when the same craftsman installed a three core the cussing and grinding was noteable. ( Hi Tony ! )
Cheers Amy
P.S. Sharif with his mod used a two core Koyo and was very succesful.
Wld350Z's two core stock install has some heat soaks and temp spikes, if I recall.... But we have had an extremely hot summer in So Cal. ( Greddy TT and E-Manage Ultima and 650 CC injectors ) This was before the Oil Cooler was added. The car is ready for HIN, but ....
Old Aug 28, 2006 | 10:56 PM
  #66
blackend's Avatar
blackend
yes our JDMZ have 2 row
Old Sep 3, 2006 | 11:10 AM
  #67
zman2's Avatar
zman2
Anybody know the weight difference between a Koyo 36mm and 54mm radiator?
SharX59
Sep 30, 2015 10:54 AM
mjgfish
Sep 22, 2015 05:55 AM
EnjukuRacing
Sep 18, 2015 07:57 AM
