Sleeves or no sleeves?
Old Mar 31, 2006 | 06:05 PM
mraturbo's Avatar
mraturbo
Originally Posted by Sharif@Forged
Sleeving helps, but even sleeved blocks are showing signs of head lift past 700whp, so I am making the assumption that head lift is the main culprit. Yes, you should be cautious.
At the level we are pushing my G35C currently in my quest to have an 800 WHP daily driver, we aren't sleeving. However, we will let you know if sleeving is necessary if she let's go. Made another near miss of 700 WHP today at only 16.5 PSI. The motor is taking 22 PSI no problem, however still getting clutch slips so we can't get a clean run.
Take care.
M
Old Mar 31, 2006 | 07:11 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Thanks for keeping us posted. I have no doubt its doable, but I seriously question the reliability of 700whp with standard ARP studs. Many guys have tuned to 700whp+, and thought everything was fine.....only to find several months later, that the head gasket started leaking.
Old Mar 31, 2006 | 11:15 PM
Philthy's Avatar
Philthy
Boost Junkie
OK - Here's some pics of my Darton MID block...
STOCK
[IMG][/IMG]
MATERIAL REMOVAL
[IMG][/IMG]
SLEEVES GOING IN
[IMG][/IMG]
Tomorrow I'll take pics of my block that has Weston spec liners in them. Both of these will work just fine for HP levels in the 1000 hp range and the cost is pretty much the same for both setups. There are some thoughts on which will work better over time and higher HP levels, but there's not enough data to support anything for sure - in a nut shell, take note on how much material needs to be removed from the block in order to install the MID kit - it's a lot. The Weston liners are beefy and don't require gutting the block and hence in theory the core is stronger -
Old Apr 1, 2006 | 05:05 AM
mraturbo's Avatar
mraturbo
It's not just 700 WHP+, We have had Head Gasket leaks at the 450 WHP level, yet on Very Very aggressive road racing. Lap after Lap the pressure builds, luckily the problem is easy to correct. Hell thin oil and synthetics can increase the chances of leaks everwhere!
Obviously at this level, anything can happen and there aren't 100% insurance policies for all occurrences. Sleeving has its values for sure, just not sure if it is only the Sleeves that are needed or longer studs heads, or bearings or ??? Everything helps yet at what cost does it make sense? Guess no answer for it is all expensive.
Too many things once again can go wrong when making huge power. Just kind of fun to do the trial and error thing. I am still an absolute Cheerleader for a perfect 500 WHP and 550 FT/LBS on these cars. Don't think too much more is EVER needed except for the DYNO and the Drag strip. However, with this much power and to use it, on the drag strip, you need a lot more than just 315 or 345 tires to use it.
500 WHP ... The power is extremely strong, competitive against other Super Cars, the tune is reliable, and this goal can be made at reasonable $$$. I kind of like consistency.
Have a nice day.
M
Old Apr 1, 2006 | 02:47 PM
t32gzz's Avatar
t32gzz
Not too mention running pump gas with little worry. But for some strange reason, I always want more. Apparently there a few of us bitten by this bug.
Old Apr 1, 2006 | 03:21 PM
1G-350Z's Avatar
1G-350Z
Can you run 1/2 inch headstuds with a 100mm Bore Darton Sleeve??? Does not look like you can...
Old Apr 1, 2006 | 03:49 PM
overZealous1's Avatar
overZealous1
would be very close for sure. but definately still room.
Old Apr 1, 2006 | 06:08 PM
Dirty Dave's Avatar
Dirty Dave
M
Im gonna be changing my oil in the next few days then having it tuned, do you suggest I use thicker non synthetic oil on my built motor ? Probably gonna tune for about 500 whp daily driven.
Old Apr 1, 2006 | 06:49 PM
mraturbo's Avatar
mraturbo
We use full Synthetics 10/30 for almost all instances. However if you always seem to have some sort of leak, try a thicker oil.
And
T32gzz
I definitely have the bug. Have had 500+ WHP for years and I end up tearing things apart (my own cars) and wanting more and more and even more. Currently working with JWT for 800 to 1000 WHP reliably on race fuel and 600 WHP on pump. Have already made 700 WHP on race and 550 on 91 pump, yet still setting the standard higher.
Like an obsessed idiot yet other than sex and love from your family, what else is better???
But to repeat, for our clients, I reccomend a perfect 500WHP/550TQ. It is easy, affordable, safe, and useable.
Goodluck.
M
Old Apr 1, 2006 | 08:26 PM
turismo's Avatar
turismo
Did you make 500rwhp on a stock block or a built bottom end mraturbo?
Old Apr 2, 2006 | 11:49 AM
Sharif@Forged
Forged Performance
Yes you can...no problem at all.
Old Apr 3, 2006 | 07:53 AM
mraturbo's Avatar
mraturbo
Both.
However. Making 500 WHP on the Dyno is just a brag number, the real test is driving 500 WHP hard everyday. I wouldn't reccomend you driving a 500 WHP car on the stock motor long without Race Fuel. Sooner or later it is burned toast.
NOTE: My G35C makes over 500 WHP on the 10.5 lbs waste gates (upgrade from the standard BB530 turbos from JWT) ON PUMP GAS. This is the same car we are striving to make 800+ WHP on. This is my personal goal, not my companies.
For VRT, we believe 500 WHP/550TQ on a built motor is the perfect set-up for this chassis and motor. Anything else with HARD driving like we do on Road RaceTracks is expensive $$$, almost unuseable unless driving straight or you know how to really drift, and risky. I have said this before and I will keep saying it.
M
SirMichael
Not Z Related Items
Sep 22, 2015 05:57 AM
IceY2K1Max
Apr 11, 2005 11:24 AM
ZliciousStroker
Jul 5, 2004 09:14 PM
