RPM Signal Heed Help fast!
Old Apr 1, 2006 | 01:23 PM
mrtomcat's Avatar
mrtomcat
Exclamation RPM Signal Heed Help fast!
My car is at brainstorm right now and amongst other things I had the Racelogic Traction control installed but it needs to get a RPM signal and since the ECU does not have a direct line for that they are kinda stuck right now and I'm hoping to get the car back today.
Anyone know where they can splice in or will I need a special adapter for this?
time is of the essence....
Thanks
Old Apr 2, 2006 | 03:18 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Call me on Monday..I have something for you.
Old Apr 2, 2006 | 03:29 PM
mrtomcat's Avatar
mrtomcat
will do
Old Apr 2, 2006 | 08:36 PM
theking's Avatar
theking
MSD tach driver! Hey I just got done installing a RLTC on my friends SC300-2JZGTE-T76 car and I have to say I was impressed. Make sure you get Graham's little program/interface. It lets you change some parameters the regular RL program won't. Here's the yahoo group that has all the programs. http://autos.groups.yahoo.com/group/RLTC/files/ It's in the Windows editor folder. Good luck. Once it's up and running you will love it!
Old Apr 2, 2006 | 08:44 PM
mrtomcat's Avatar
mrtomcat
the king to the rescue again...very cool I was searching around for a group like that.
I can't wait to try the RLTC
Old Apr 3, 2006 | 10:52 AM
theking's Avatar
theking
Glad I could help. Let us know how it turns out.
Old Apr 3, 2006 | 12:10 PM
mrtomcat's Avatar
mrtomcat
I ordered the greddy rpm adapter and had it overnighted. It's only $10 compared to the MSD. Hopefully it makes it to brainstorm by tomorrow.
thanks for your help Sharif
Old Apr 3, 2006 | 12:11 PM
eat rice z33's Avatar
eat rice z33
i tapped the feul injector #1 for singal because it doesnt use CAN bus, however its not working with my shift light :sad
Old Apr 3, 2006 | 01:06 PM
mrtomcat's Avatar
mrtomcat
racelogic actually replied back as well and stated that Crank Angle Sensor and Fuel Injector is not sufficient for this. They recommend the negative side of a coil pack
I still don't get why one can't just splice into the tach on the dash cluster...I mean it's getting the signal from somewhere doesn't it?
Old Apr 3, 2006 | 01:11 PM
eat rice z33
o the reason you cant use the actuall tach wire is because it doesnt use a typical +12 volt signal, it uses whats callec CAN BUS which is basically micropulses of data that you cannot interpret without a computer. my shift light needs a 5-12 volt readout and i thought the injector would do it! after tapping it i now know it doesnt work. This dam thing has given me so much grief
Old Apr 3, 2006 | 03:14 PM
mrtomcat's Avatar
mrtomcat
try the crank angle sensor KP is using that for their shift light and it seems to work
Justin100
Nov 29, 2015 03:58 PM
Depravity
Oct 1, 2015 04:49 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
