12psi daily driven?
Old Oct 8, 2007 | 02:06 PM
booger's Avatar
booger
Originally Posted by chris'smax
no,
It was a 2000 maxima which came originally equiped w/ a vq30. I swapped in a vq35 using the the timming components from the vq30. In order to do this you had to use cam re-position adaptors in order to use the Vq35 cams (nismo cams in my case). After multiple attempts to get the cam timming right and using several set of adapters i gave up and swapped in the vq30 cams. Then when we hooked up the blower it started making noises (not sure if it was a bearing issue or not). After all the headaches i finally sold the car w/ just the vq35 in it and bought a new Z. Been happy ever since
BTW a guy followed up behind me and completed the same exact setup a few months later and made like 430whp. Needless to say i was pissed my setup didn't work out.
So Chris...what happened that things didnt work out for you on this set up ? Couldnt get to 13psi with out belt slip ?????
Old Oct 8, 2007 | 05:15 PM
chris'smax's Avatar
chris'smax
nah i could never get the cam timming right with the nismo cams so i ended up using the stock cams.
I know on the maximas guys will use a 2.62 pulley and sometimes see around 14-15psi without belt slip problems
Old Oct 8, 2007 | 06:08 PM
booger's Avatar
booger
Must have not been installed right . Im running the nismo cam with no problems
Old Oct 8, 2007 | 06:35 PM
TurboTim's Avatar
TurboTim
Vendor - Former Vendor
He was doing this using a VQ30 ECU. It was a VQ30 to VQ35 swap from what I gathered.And he needed the VQ30 cam sensor because the VQ35 didnt work with the VQ30 ECU so he was trying to get the timing right using the right sensor with the wrong motor.I guess it didnt happen.
Old Oct 9, 2007 | 04:40 AM
chris'smax's Avatar
chris'smax
correct tim, but i did get the motor running. For some reason though when we used the nismo cams with the cam position adapters we had made the cam timming would be all f'd up. Thats why i used the stock cams so i would not have to use the adapters(which more than likely were not dialed in right).
Old Oct 9, 2007 | 04:47 AM
dozzer1b's Avatar
dozzer1b
Originally Posted by Audible Mayhem
WTF is going on??
+1000000000000000
350Z_Al
Oct 29, 2020 07:44 PM
HoBrahYouStink
Jun 24, 2016 10:58 PM
kyin
Oct 15, 2015 05:54 AM
