460whp 380wtq Vorteched Z courtesy of AAM
Old Apr 6, 2006 | 11:27 AM
jpc350z's Avatar
jpc350z
Sharif,, explain please why the Return System helps.. If w/o it and the injectors are at less than 80% with good fuel pressure and the A/F is in the 11/12 range accross the board what effect does it have on power?
Old Apr 6, 2006 | 11:43 AM
sja177's Avatar
sja177
I cant imagine running 460whp on the stock system, I find it really hard to belive that his fuel pressure would be normal with that much power.
If you are running with less than 80% duty than you are lucky, because I ran out of fuel from 5800rpm with my 440/walbro
maybe your fmu acts as the aermotove fpr would?
Old Apr 6, 2006 | 11:45 AM
sentry65's Avatar
sentry65
the burninator
sja177, what whp were you putting down with the 440's?
Old Apr 6, 2006 | 11:51 AM
DB350z3469's Avatar
DB350z3469
Originally Posted by Sharif@Forged
The AAM fuel system really help you here. NICE numbers, and hats off to Mike.
What pulley are you running? How much boost at redline (Sorry if I missed it somewhere else in this thread).
Im running the 2.87, ive seen 12psi at redline.
OldManZ350's Avatar
OldManZ350
I'm using Stock injectors with the Stock Vortech Fuel System. I'm am seeing some fuel starvation, after 6200rpm it begins to lean out from 11.8 to about 12.2 at 6600rpm. (I know i need to upgrade)
Old Apr 6, 2006 | 12:04 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
This car is running an AAM return fuel system, so fuel shouldnt be an issue. With a proper return fuel system, and a 1:1 riser, you establish solid and stable differential fuel pressure. This makes tuning more accurate, safer, faster, and allows you to adjust your fuel pressure to suit your needs.
Old Apr 6, 2006 | 01:12 PM
Mike@Altered's Avatar
Mike@Altered
Chris's 350Z is awesome!
We removed the Vortech fuel pump which overdrives the injectors. He currently has the AAM Fuel System, Walboro fuel pump, and 550cc injectors. His engine is stock (no cams yet!) with a spacer, exhaust, and radiator.
For tuning we are using a combination of the AAM ECU Flash (for timing control and raised rev-limit) and the Split-Second box (used for fuel control only).
By redline we are seeing 10.5-11psi of boost on pump gas without a problem Uncorrected, Chris's Z nearly made just under 470rwhp!!
Old Apr 6, 2006 | 01:21 PM
EM-EFER's Avatar
EM-EFER
Impressive.. I think you may be the new Votech king.
Old Apr 6, 2006 | 01:22 PM
booger's Avatar
booger
what were the corrected numbers ?
Old Apr 6, 2006 | 01:24 PM
EM-EFER's Avatar
EM-EFER
Those are the corrected number on the dyno chart. He said uncorrected was nearly 470whp.
Old Apr 6, 2006 | 01:36 PM
jazz z1's Avatar
jazz z1
DB350z3469 (CHRIS) Congrats on the impressive numbers. How loud is the Vortech's gear noise at idle? Or did you increase your idle speed to cancel the noise.
Old Apr 6, 2006 | 01:37 PM
leemik's Avatar
leemik
holy crap.. NICE numbers!!
Old Apr 6, 2006 | 01:42 PM
backagain's Avatar
backagain
do you not have a dyno with air fuel, im curious to see how the air fuel looks throughout the rpm. im also planning on the AAM return fuel and 2.87 in the next few weeks.
Old Apr 6, 2006 | 01:45 PM
teh215's Avatar
teh215
How does the SS box control fuel if the AUX pump is gone?
Old Apr 6, 2006 | 01:47 PM
teh215's Avatar
teh215
Originally Posted by DB350z3469
flexlight fans
Are switching to these fans the key to being able to use the Koyo radiator? What size fans did you use?
Old Apr 6, 2006 | 01:53 PM
DB350z3469's Avatar
DB350z3469
its not loud at all, and u hear is a slight whistle cant even hear it with the windows up, idle is stock
Old Apr 6, 2006 | 01:58 PM
DB350z3469's Avatar
DB350z3469
Ithey tried to trim the factory fan shroud, but it didnt work. Im not sure what the size was, Noah at AAM would know they had the flexlight fan in stock, when i got the radiator installed. so i just purchaced it while i was there.
Old Apr 6, 2006 | 02:02 PM
  #38
Mike@Altered
The SS box, although not nearly as nice as the GReddy E-Manage or UTEC, can be programmed to modify the factory air-meter signal. The SS Box uses a map sensor so you can program above 6/7psi.
The end result is modifying the fuel very similar to how the GReddy E-Manage Blue does.
Hope this helps,
Old Apr 6, 2006 | 02:04 PM
  #39
backagain's Avatar
backagain
mike, do you have a dyno with air fuel printed on it ?
Old Apr 6, 2006 | 05:45 PM
  #40
zachcrosen's Avatar
zachcrosen
Subscribing.
